Instruments and Amps Everything that makes music, Especially including instrument amps.
cassette tape echo / delay
Old 29th June 2004, 09:23 PM   #1
thegunshyboy is offline thegunshyboy  United States
Default cassette tape echo / delay
i recently went to a show where it appears they used an ancient looking cassette player as a homemade tape echo. about a week later i found an old cassette player in my basement, and am wondering if i can make my own tape echo? any thoughts/ideas on how to do this? thanks
Old 5th July 2004, 02:27 PM   #2
diyAudio Member RIP
No easy way of doing this at all.
sreten.
Old 5th July 2004, 02:54 PM   #3
moamps is offline moamps  Croatia
This is possible if cassete player has dual head and two separate electronic. Then you can monitor in real time something what cass record. Echo-delay depends of record and play head distance and tape speed. For example, in profi Teac cassete player this distance is ca 5mm and for tape speed of 4,75cm/sec, delay is about 100ms. If your player has pitch control, you can vary this delay, but if tapes speed is smaller, recording quality is smaller too (HF response and higher noise).
This technique works well if profi tape maschine (1/4") are used(Tascam, Revox..) at higher speeds (19 or 38 cm/s).
Milan
Old 5th July 2004, 03:52 PM   #4
Steve Eddy is offline Steve Eddy  United States
Steve Eddy's Avatar
Sure isn't.
Might just as well buy an old Maestro Echoplex. Hell, you can still find the old tube-based units.
se
Old 5th July 2004, 04:50 PM   #5
diyAudio Member RIP
Any Echoplex you can find restored to fine fettle,
especially valve, is an excellent investment IMO.
sreten.
Old 6th July 2004, 09:05 AM   #6
electroaudio is offline electroaudio  Sweden
Default Re: cassette tape echo / delay
I think you, are much better off if you start from scratch than to rebuild a casettedeck.
It would be quite easy to put everything you need to move and steer an endless tape onto an iron (or wood) plate and then screw on some old monoheads with their electronics onto it.
Best is if you make the readinghead(s) moveable so you can change the delay by moving the heads rather than to change the speed.
Hmm, that sounds like a fun thing to do actually...
Old 12th October 2004, 10:13 AM   #7
rekem1000 is offline rekem1000  Australia
Thumbs up Homemade Tape Echo can be done!
Yes, tape echo's can be made cheaply . I built one myself using an old reel to reel and 4 walkmans. Here's how I did it.
1. old portable reel to reel with record function (portables are easier because they lie flat)
2. four walkmans taken out of their cases front and back (just the motors and electronics) mounted on on L shaped piece of steel I just screwed them on and then attached to the side of the reel to reel.
3. next I took the spools out from 4 cassette tapes, except the last one has one spool in it to pull the tape.
the tape pulls through the record on the reel to reel and passes through each walkman. The head phone out on each walkman has been resoldered to one set of left and right rca's, the volume control on each walkman acts as the delay time and amount, e.g. no volume on walkman 1,2,and 3 equals one longer delay time, volume on all 4 equals 4 step delay. Because the motor in the walkman is weak you can pull and slow down the tape by hand on the reel to reel creating wierd effects.I have a Roland 201 Space Echo that cost me $350 I can get remarkably similar sounds with my "Space Walkmans" for a cost of 45$ after searching garage sales. Only thing is to use long tape, because it doesn't loop you have to rewind it, my tape lasts for 45 min before I have to rewind.
I hope this isn't to confusing, try it yourself if you have the time and patience.
Old 12th October 2004, 08:48 PM   #8
ubieflare is offline ubieflare  United States
this is exactly what i was thinking of doing, rekem1000!!
Do you have any pics or more details? How about some audio clips?
I'd love to know more about it.
Thanks.
Old 13th October 2004, 12:48 AM   #9
Enzo is offline Enzo  United States
Gunshy, you can make an echo out of any tape deck that has separate record and playback heads. Most cassette ddecks have a single record/playback head - a dual purpose head. But some have separate heads. You put the deck into record mode, then monitor the playback head. Due to tape motion, the playback head will be lagging behind the original signal. Mix the delayed signal back in with the original and you get echos. Feed some of the delayed signal back into the system and you get repeating echoes. Multiple heads were far more common on reel to reel decks.
Old 23rd November 2006, 08:58 PM   #10
AnG3L is offline AnG3L  Portugal
I'm also interested in that
Tomorrow I guess, I'll buy an old tape recorder, probably those old ones with big tapes
Then, using some part's of steel, iron and stuff will try to develop a reliable system... don't care if it was to big, cause it will be fitted in a box like echoplex.
But have one question, in case of echoplex units, wich is ussualy the speed of the motors that drive the tape?
Happy DiYing
cassette tape echo / delayHide this!Advertise here!
tape echo search infobot Instruments and Amps 16 11th October 2013 12:24 AM
Analog tape echo Limhes Analogue Source 3 24th January 2007 07:45 AM
PT2399 Echo / Delay Audio chip -_nando-_ Digital Source 1 28th August 2006 02:53 AM
Delay - echo through BL and FL horns jamikl Multi-Way 4 3rd April 2006 06:52 AM
Tape Cassette Mechanisms TonyD Parts 0 10th April 2004 05:37 PM
Copyright ©1999-2017 diyAudio
