Instruments and Amps Everything that makes music, Especially including instrument amps.
No internal power Valvestate 8280
Old 22nd July 2018, 04:00 AM   #11
Gnobuddy is offline Gnobuddy  Canada
Originally Posted by Enzo View Post
Those regulators are just sticking up from the board, no support.
I noticed that, and the PCB markings that suggest the regulator body was intended to lie flat on top of the PCB. No through-hole in the PCB to bolt down the regulator's heat-sink tab, but at least it wouldn't be so tall and prone to vibration.
I wonder if those regulators have already been replaced once?
-Gnobuddy
Old 22nd July 2018, 04:15 AM   #12
Originally Posted by thoglette View Post
Don't forget the other option: a bad day at the factory.
I soldered something for a work colleague recently, and was mortified when he brought it back with a loose connection. I had made the worst cold-solder joint I've produced since I was maybe ten years old.
-Gnobuddy
Old 22nd July 2018, 08:23 AM   #13
prospect is offline prospect
I am grateful about your support.
Very appreciated.
I bought it second hand so I do not have the complete story but after some months of use it lost power. It was fixed for free and I was told it was a cold-solder joint. If I remember correct the fan did not start as well.
So yes, it has been repaird before.
As you see in the pic there are visible cracks at pin 1 and 3. When wiggle the reg pin 1 and 3 moves on the back of the PCB but not pin 2. I removed the reg and as I suspected, pin 2 is broken at the PCB. Interesting that it could work flawless but break next power on.
The value between pin 3 and 5 is aprox 1.9 Mohm.
Could the broken reg pin 2 caused the problem?
Old 22nd July 2018, 09:05 AM   #14
Cannot buy the parts locally.
Anything else I should order/update?
Old 22nd July 2018, 01:19 PM   #15
voltwide is offline voltwide  Ireland
For me it is not evident that this regulator failed at all.
Did you re-flow the solder joints of the regulator?
Did you check it afterwards?
You could check this by inserting some fuse like 1A slow blow or similar.
Old 22nd July 2018, 08:44 PM   #16
That's good news - firstly it means the TDA2030 is not shorted, and secondly, it also means nothing else is shorting across the power supply, either.
I'm with Voltwide and Enzo. If there is no evidence of overheating, just try re-soldering the regulator onto the PCB. It may not be damaged. (You will need to replace the fuses with good ones too.)
I just realized I'm assuming - do you have a soldering iron? Do you have any previous experience soldering on printed circuit boards? Those thin copper traces are quite delicate, especially when they are heated up for soldering, and can be damaged by rough handling. This is another reason to just try re-flowing those two solder joints, rather than trying to remove the regulator completely - it is easy to damage the PCB by using the wrong techniques when removing a part.
-Gnobuddy
Old 2nd August 2018, 12:25 PM   #17
I got the parts yesterday since I did not order them directly.
I am not used to work on PCB’s but I have a solering iron.
Thanks for the concern and advice.
I fitted the parts this morning.
24v at the connector and the amp seems to work as it should.
All of you, thanks for the support to solve the issue.
Old 2nd August 2018, 05:07 PM   #18
Congratulations! Nothing's better than a happy ending!
-Gnobuddy
No internal power Valvestate 8280Hide this!Advertise here!
Add audio interface to Marshall Valvestate power amp mikst Instruments and Amps 3 3rd July 2018 09:06 PM
Marshall Valvestate 8080 and Laney tf200 Power transformers missing! Lina Instruments and Amps 5 28th November 2012 07:02 PM
Marshall AVT150H Valvestate 2000 Power Amp Problem fenster94 Instruments and Amps 10 22nd May 2011 02:56 PM
Best internal wiring for power Jonasa Tubes / Valves 5 29th October 2007 08:23 PM
Marshall Valvestate Pro 120/120 power amp schemayic ???? darkiller86 Instruments and Amps 2 4th September 2005 04:26 PM
