Instruments and Amps Everything that makes music, Especially including instrument amps.
Add audio interface to Marshall Valvestate power amp
Old 3rd July 2018, 03:14 PM   #1
mikst is offline mikst
Default Add audio interface to Marshall Valvestate power amp
Hello,
I am thinking of connecting the Out line from an audio interface to the power-amp with phone jacks to be able to chose between build-in pre-amp or the external interface.
Has anyone tried this?
Could this create any problem?
Do I need to build any input filter?
Old 3rd July 2018, 03:54 PM   #2
JonSnell Electronic is online now JonSnell Electronic  United Kingdom
JonSnell Electronic's Avatar
That will work fine but you will lose the valve compression when using alternate signal sources.
Support for Fender, Marshall and all Valve Equipment; Audio Innovations, Audiorama FU29, Quad and Leak. www.jonsnell.co.uk
Old 3rd July 2018, 07:50 PM   #3
Thanks for the support.
The Idea is to make some kind of modeled combo with existing gear where I can test different guitar SW.
Since I need an interface for a mic, I Will try this solution.
Old 3rd July 2018, 09:06 PM   #4
nigelwright7557 is offline nigelwright7557  United Kingdom
nigelwright7557's Avatar
You could use a cheapo 2 channel mixer on the input.
Even a couple of pots and a couple of resistors to mix the signals.
PCBCAD51 pcb design software. 2018 version out now with lower prices >> http://www.murtonpikesystems.co.uk
Add audio interface to Marshall Valvestate power ampHide this!Advertise here!
Marshall Valvestate mods Nelec Instruments and Amps 22 10th June 2013 01:01 AM
Marshall Valvestate 8080 and Laney tf200 Power transformers missing! Lina Instruments and Amps 5 28th November 2012 07:02 PM
marshall valvestate 8100 trai1824 Instruments and Amps 4 27th March 2012 01:36 PM
Marshall AVT150H Valvestate 2000 Power Amp Problem fenster94 Instruments and Amps 10 22nd May 2011 02:56 PM
Marshall Valvestate Pro 120/120 power amp schemayic ???? darkiller86 Instruments and Amps 2 4th September 2005 04:26 PM
