Instruments and Amps Everything that makes music, Especially including instrument amps.
increasing gain in preamp fet / op
Old 18th June 2018, 02:11 AM   #1
Pauld35 is offline Pauld35  New Zealand
Default increasing gain in preamp fet / op
Hello
I'm looking at ways to increase the clean gain of channel green in the schematic below,it does not have to be variable though it would be good to dial it in then set with fix resistors.
I thought the fet would be best as its later in the circuit. I looked for info on the net but can only find stuff for the designs where signal comes out from drain where this design is from the source. and of course alot of formulas i cant understand. I am guessing there is away to increase the gain on the fet using the resistor network R4/R5 in the second schematic copy but have no idea where to start and if the divider values must stay equal or if R3/1M should change as well.
the other option I though was to add gain to the first op stage though im not sure what values to use for R1 or R2 or if R1 should connect to ground or v-ref or some where else
i think the last op stage with the switched phase is to complicated for me to increase the gain on. I have tried with out any luck.
Any advice on where to start would be appreciated, thanks
Old 18th June 2018, 02:52 AM   #2
rayma is online now rayma  United States
R1 must go to a capacitor to ground. The positive capacitor terminal goes to the resistor.
The gain factor of that stage is (1+R2/R1). For example, let R1=10k and C =100uF.
If R2=90k, the gain is x10, or 20dB.
The source follower fet stage won't add any gain, leave it out.
Old 18th June 2018, 03:07 AM   #3
steveu is offline steveu  United States
This gives 10dB
Old 18th June 2018, 03:20 AM   #4
Thanks, is the source follower the 1M from the gate to source?
Old 18th June 2018, 04:06 AM   #5
Originally Posted by steveu View Post
This gives 10dB
Thats awsome thanks
Old 18th June 2018, 04:13 AM   #6
This gives 10dB
Hello Steveu,
in your schematic should the 100k go to earth or v-ref? ta
Old 18th June 2018, 04:31 AM   #7
radtech is offline radtech  United States
No, the whole FET circuit is a source follower configuration, also known as common drain. Input on the gate, output on the source, voltage gain is approximately 1. Generally used to match a high impedance to a lower impedance.
Old 18th June 2018, 04:32 AM   #8
V-ref, ie half the power supply.
Old 18th June 2018, 10:59 AM   #9
worked well, thanks guys
Old 20th June 2018, 03:22 AM   #10
This gives 10dB
hello steveu,
do you think the phase switching will still work now the resistors to the inverting input and non inverting input are different values or should i change the 220k on the non inverting input to 68k as well to keep them matched? here is adjusted schem
increasing gain in preamp fet / opHide this!Advertise here!
Nakamichi 482Z play amp - increasing gain df_genius Analogue Source 2 1st December 2015 03:22 PM
Increasing gain from DSP with TL074 to UCD Class D Insomnia Class D 3 4th August 2014 05:17 PM
Increasing gain in ebay PCB df_genius Headphone Systems 6 8th October 2011 12:39 PM
Increasing Gain on Sub Amp jakelm3075 Solid State 21 17th April 2006 03:02 AM
DI guitar direct input box - increasing gain? bubbamc119 Instruments and Amps 10 30th June 2005 01:22 AM
