Trace Elliot AH1000-12 schematic needed
I've bought a Trace Elliot AH1000-12 with one power amp module blown.
Is there someone that can share its schematic?
I would like to repair it, otherwise to substitute it with two class D power amp modules, keeping the power supply as is. Due to the higher efficiency of class d amps, there will be two paths: keep the same output power and make the power supply's life easier, or increase a bit the possible output power. I'd go for the former, as 1000 W are absolutely more than what I'll never use.
Thank you in advance
