Instruments and Amps Everything that makes music, Especially including instrument amps.
help to diagnose simple fault please
Old 19th April 2018, 12:23 AM   #11
Pauld35 is offline Pauld35  New Zealand
its working again, i had the heater on last night when it was failing, today is alot colder when i took the readings and it seems to be working fine, unusual.
Old 19th April 2018, 02:55 AM   #12
turk 182 is online now turk 182  Canada
make sure it's not a bad connection that is affected by temperature.
one thing that seems odd/ weird about that schematic that i may be not understanding correctly is where is the supply switching? shouldn't the battery B+ be switched via the input jack to prevent battery drain? no battery clip in the drawing nor is there a dc jack which to the best of my recall is a feature on most Dunlop wahs?
or is this meant to run off a supply?
Old 19th April 2018, 03:28 AM   #13
JMFahey is online now JMFahey  Argentina
JMFahey's Avatar
Battery positive is always connected and negative is connected to ground through the input (or output) jack ring connection, when plugging a cable there; itīs the typical pedal supply switching system, so common that nobody bothers to draw it in detail, it is a given.
And thatīs not the Factory schematic but an amateur builderīs one.
Design/make/service musical stuff in Buenos Aires, Argentina, since 1969.
Old 19th April 2018, 06:46 AM   #14
Mooly's Avatar
I agree that those voltages are good.
The best thing you can do is just use the device and see if the problem recurs. If it does then leave it running in the faulty state and re-measure the same voltages.
Old 19th April 2018, 08:03 PM   #15
Gnobuddy is offline Gnobuddy  Canada
Originally Posted by Pauld35 View Post
it would only work briefly...when i disconnected the 9v battery or the 9vdc adapter power supply.
Perhaps there is a bad (cracked) solder joint or PCB trace, or a broken wire, either in the battery connector, or the soldering to the power jack.
Failure of soldered joints and wires in these areas is relatively frequent, because both these areas experience repeated mechanical stress as batteries are plugged in or unplugged, and the external power plug is inserted and removed.
The fact that the circuit did work on a 5V power supply may turn out to be a red herring - does it always work reliably on the 5V power supply, even if you wiggle the power plug and/or battery connector?
-Gnobuddy
help to diagnose simple fault pleaseHide this!Advertise here!
Fault Rickyeric Solid State 0 3rd March 2015 03:16 PM
501bd fault ian33 Car Audio 13 22nd December 2014 02:27 AM
Op amp fault? fap Analogue Source 4 6th December 2013 07:48 PM
What is the fault with this amp? analogadikt Tubes / Valves 3 6th April 2011 02:27 AM
Pre amp fault Addolff Parts 4 6th January 2008 01:55 PM
