Instruments and Amps Everything that makes music, Especially including instrument amps.
Korg Stage Echo transformer?
Old 14th March 2018, 10:58 AM   #1
Alexwfm is offline Alexwfm
Default Korg Stage Echo transformer?
Hello,
I'm fixing a Korg Stage Echo 300 that has a shorted bias IF transformer.
As expected I couldn't find any markings on the part as well as the schematic that only shows it's variable, center tapped on both primary and secondary.
..what would you do in this case?
I can see a short on the secondary and if I lightly touch the casing of the transformer the primary also shorts making the current limiting resistors (39ohms) burn.
I attached the bias circuit.
Thanks in advance.
Alex
Korg Stage Echo transformer?Hide this!Advertise here!
B1 with Korg Triode Nelson Pass Pass Labs 240 15th July 2018 12:56 PM
KORG AX-3g modification vangelis Instruments and Amps 15 23rd October 2016 03:56 AM
Korg stage echo se-500 troubleshoot opend Analogue Source 10 19th January 2015 05:48 PM
2 X PIONEER CDJ-1000 MK3 PLAYER, Korg M3 88-Key Workstation / Sampler,Yamaha Korg holocoast Vendor's Bazaar 0 22nd August 2009 07:03 AM
Just ordered a Korg EMX-1 MikeHunt79 Tubes / Valves 5 19th May 2008 08:34 PM
