Instruments and Amps Everything that makes music, Especially including instrument amps.
Laney LC50 sounds muffled/distorted
Old 12th March 2018, 02:23 PM   #1
opauly is offline opauly
Default Laney LC50 sounds muffled/distorted
Hello! My LC50 combo sounds awful. In any setting the output is distorted, with very low output and muffled-like sound. I already tested with a tube tester and a multimeter:
- Tubes
- Grid and cathode resistors
- Speaker
- Bias voltage
And some other tests, but all components seem to be fine. Any hint of what could be causing this?
Old 12th March 2018, 03:41 PM   #2
JMFahey is online now JMFahey  Argentina
JMFahey's Avatar
Try the speaker with another amp and yours with another speaker.
Try feeding clean audio into loop return or power amp in, if available,also send preamp signal to another amp.
So you split the combo in 3 (pre/power/speaker) to at least isolate the bad area, then we can concentrate on it.
That said, you *might* have a dead/shorted OT , but weŽll cross that bridge when we get there.
Design/make/service musical stuff in Buenos Aires, Argentina, since 1969.
Old 12th March 2018, 06:55 PM   #3
Thanks for the reply. So you say to connect the amp as the picture?
LC50 Manual
Old 13th March 2018, 02:16 PM   #4
I think I got to the problem. After bypassing the effects loop, the amp returned to normal conditions, so the issue was probably dirty jacks. I cleaned the jacks and maybe need to replace them. Thanks for the help JMFahey!
Laney LC50 sounds muffled/distortedHide this!Advertise here!
Blues Junior sounds muffled opauly Instruments and Amps 13 5th March 2018 02:45 PM
Musical fidelity A1 all recapped but sounds muffled cretaceous Solid State 12 14th September 2012 07:34 AM
Rotel RCD950 sounds distorted Bartt Digital Source 1 27th March 2009 09:53 AM
Speaker problem - sounds muffled wixy Full Range 6 5th September 2006 10:59 PM
