Instruments and Amps Everything that makes music, Especially including instrument amps.
Building a pair of valve combo-practice-amps
Old 22nd February 2018, 01:14 AM   #21
thoglette is offline thoglette  Australia
thoglette's Avatar
Originally Posted by Bigun View Post
For learning, I expect it to be mostly clean.
If you can find a Vox Pathfinder 15R cheaply, grab it.
It's got some of the best clean tones you'll find at a budget price point. With tremolo and an OK spring reverb thrown in.
Yes, your valve amp will sound better. But if you're anything like the rest of us it'll be constantly on the bench being "improved"
Originally Posted by Gnobuddy View Post
Check out Gilmourish.com
+1 gilmourish.com is a damn good read even if you're not interested in Mr Gilmour.
Old 22nd February 2018, 01:34 AM   #22
Bigun is offline Bigun  Canada
Bigun's Avatar
No, I can't go buying an amp now, I'd never finish the darn thing I've started ! besides, I have a Traynor on loan from a buddy.
Now the sides are glued on. The box is one solid piece of glued up wood. Well, it's hollow. Nice chunky pine and a pair of boxes 17.5" x 16" x 8.75". I think that's a good size.
Thanks for the encouragement Gnobuddy and the link to Gilmourish is great ! much for me to mine from there although I don't think my Tele is the best starting point necessarily but who knows what might be possible :-)
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig.
Old 22nd February 2018, 02:58 AM   #23
Gnobuddy is offline Gnobuddy  Canada
On DVD, I've seen Gilmour play half a dozen different electric guitars during a single show. If you're not looking, you may not hear a change of guitars at all. Gilmour with an electric guitar in his hands always sounds like Gilmour.
I bet if you gave David Gilmour a tennis racket for a guitar, and a fifty-cent coin for a guitar pick, he would still manage to produce sounds so beautiful they make our noisy minds go quiet for a second.
It's only us lesser mortals that feel we need to have exactly the right equipment to get anywhere!
That said, IMO, the most useful guitar pedal you can own is a graphic EQ. It's astonishing how much you can change the sound of a guitar (or an amp, or an FX pedal) with one.
It looks like your amp is coming along fast, nice work!
-Gnobuddy
Old 22nd February 2018, 03:05 AM   #24
thoglette's Avatar
There's a nice video of DG playing a solo on an acoustic guitar on Seymour Duncan's
How to sound like David Gilmour page.
Yes, he still sounds like him. (He does crack out a pedal for the solo)
Old 22nd February 2018, 05:47 PM   #25
Bigun's Avatar
I need to pick a power transformer. As my sister is in the UK it means one that works with both Canadian and UK supply voltage & frequency. Locally I can get Hammond iron. There seems to be two choices
a) 260A ($60) 200-0-200 @40mA and 6.3 @1A
b) 369EX ($65) 190-0-190 @75mA and 6.3 @2.5A
The first one is lighter in weight (I think) which is a benefit. Nothing to choose based on price difference. But I fear the first one doesn't have the VA for the job as I'll be using all of it's current capacity and plus I plan to use a capacitor input filter after the rectifier so the transformer really should be rated at more current. My experience with Hammond power transformers is that they run really hot if pushed. So I'm seeing the 369EX as the only option here. Unless you know otherwise ? (Edcor say, in not so many words on their website that most of their transformers are build to order so they have long lead times and I'm not that patient).
Old 22nd February 2018, 09:00 PM   #26
The schematic you posted uses a 250-0-250 transformer secondary, and a full-wave rectifier. I can't for the life of me think of a good reason to do that, when you can use a single 250V secondary and a diode bridge to get the same DC voltage.
If you're willing to provide the heater power from a cheap switch-mode DC power supply, use a bridge rectifier, and settle for 230V AC (rather than 250), this might be an option, at half the price of the Hammond: A41-43-230 Bel Signal Transformer | Mouser Canada
The datasheet is here: https://www.mouser.com/ds/2/643/A41-1131073.pdf
In the USA, wire both primaries in parallel and both secondaries in series to get a nominal 230V AC. In the UK, wire both primaries in series, and also both secondaries in series, so you have a 1:1 ratio, 230V:230V transformer.
There is a beefier (80VA) version as well, but the price difference from the Hammond vanishes: A41-80-230L Bel Signal Transformer | Mouser Canada
I would expect somewhere between around 330 - 350V DC using a bridge rectifier and capacitor with a 230V secondary. That seems about right for a 6V6, at least in my world (not Leo's.)
Something like this ( TRG1506-A-11E02-Level-VI Cincon | Mouser Canada ) should happily supply the heater power you need for an EF86, a 12AX7, and an EL84 or 6V6.
With DC heater power, you no longer need black magic to get hum-free performance. In 1930 you had no choice, but here in 2018, DC heater power from a switch-mode power supply makes so much more sense than the ancient alternative.
You may be able to tweak the nominal 6V DC up to 6.3V DC - there is often a trimpot inside these switching power supplies.
Alternatively, you can use a supply that puts out more than 6.3V, and drop the excess voltage in a power resistor. I use a Sony 8.4V switching power supply in one of my amps, with a series resistor to drop the voltage down to 6.3V at the heaters.
-Gnobuddy
Old 22nd February 2018, 10:32 PM   #27
PB2 is offline PB2  United States
PB2's Avatar
Have you looked at the Hundred Buck amp thread here? You might find some tips to cut costs.
Old 22nd February 2018, 11:15 PM   #28
Bigun's Avatar
Hi Guys,
some interesting options !
I must admit I'm wasn't feeling comfortable with the SMPS option simply because I wanted to build with parts I can see and touch and repair rather than use modules that are essentially a black box - it's not so much a rational issue as an emotional issue !!!
Cost is not a prime driver, but I like the 'challenge' of using up parts and materials I have at hand and then buy the minimum to achieve the goal. It's a perverse pleasure really since I could easily buy an amp and have done with it but I like to make things.
I could go with the Bell transformer you recommended and add a Hammond 266JB6 heater transformer for a traditional supply. The total weight is about the same as a single 369EX and the cost a bit less but not enough to worry about. The advantage of the separate heater supply is no rectifier pulses from the HT supply leaking into the heater circuit. The advantage of the 369EX is that it's encased and therefore a much safer option for anybody sticking their hand up inside the box when the power is on.
Gnobuddy - good catch on the schematic as I hadn't notice the supply voltage. Most of the other AC4 circuits seem to aim around 250V but the one I posted is closer to 300V (allowing for the 50V drop across the power supply 1k series resistor). I guess anywhere in this range is going to do the job.
My guitar teacher has asked me to practice with a metronome. It has been a most irritating experience, like being micromanaged or something - I bet Gilmour didn't have to do it.
Old 22nd February 2018, 11:52 PM   #29
LeftHandFool is offline LeftHandFool  United Kingdom
I'll bet he did...
Regardless, practicing to a metronome is something you'll thank yourself for persevering with in the long term.
I'd been 'playing' for well over a decade before I knuckled down and learned to play in time. Boy, were those bad habits hard to break!
Do yourself a favour and do it right from the off. Trust your guitar teacher, they know best .
Matt.
www.falderguitars.com
Old 23rd February 2018, 12:02 AM   #30
PB2's Avatar
I like this one: YouTube
Building a pair of valve combo-practice-ampsHide this!Advertise here!
Kicking a dead pig - upgrading low-end practice amps ericj Instruments and Amps 30 30th June 2017 01:30 PM
Less than 1w practice guitar amp Tube Valve tehmessiah Instruments and Amps 11 20th December 2016 03:01 AM
Digital source and valve amp combo. Good or bad set up? matt scarlett Digital Source 17 18th May 2015 06:11 PM
TAD TH-4001 horns plus a pair of Brass tweeter combo danVeyron Vendor's Bazaar 1 4th May 2014 02:14 PM
Building combo amp for stage piano MBAnderson Construction Tips 4 29th July 2012 09:15 PM
