Instruments and Amps Everything that makes music, Especially including instrument amps.
Mic preamp without input transformer
Old 8th February 2018, 03:17 AM   #21
famousmockingbird is offline famousmockingbird  United States
Originally Posted by 6V6dude View Post
The cathode follower should provide about 300 ohm so overloading the output is not a problem since the highest load I put on it is 10k.]
Except you have a pot at the output which I would think depending on where the wiper is will raise the output impedance significantly. Especially if you are feeding a lowish z input (like 10k) and a long cable run. See if the tone gets better when turning the output volume to maximum.
Other than that I agree with the fact that the microphone you are using is terrible. I never liked the sound of those for vocals.
Old 8th February 2018, 07:51 AM   #22
6V6dude is offline 6V6dude  Australia
Yes the SM57 can be quiet midrangey which probably adds to the "effect" but I did use other mikes and still get that unpleasantness although not as prominent. But I need to use to SM57 for instruments anyway so I can't escape it by changing mic. When I use SM57 with SS preamp, it is quiet normal, nothing annoying that I hear.
The lowering of the input resistor is worth a try. I thought 1.8k was fairly average value found on many preamps so used that. I'll also try with the output on max and see if it's different.
I just wish there was a way to measure it without a scope. Listening tests can be so deceiving. I'm basically just stabbing in the dark here. But thank you for trying to help.
Mic preamp without input transformerHide this!Advertise here!
Input transformer q for tube preamp jazzzman Analog Line Level 10 23rd June 2017 07:52 PM
Mic Preamp w transformer input: changing impedance tubeing Analog Line Level 3 12th September 2014 05:38 PM
Mic preamp input transformer alternative? Andyroid Instruments and Amps 44 19th May 2014 06:21 PM
How to make mic input transformer 150:50KCT for mic tube preamp??? delipasha Instruments and Amps 9 3rd February 2012 05:54 AM
Suggestion on the input transformer for tube preamp bee696 Tubes / Valves 3 2nd August 2006 04:43 AM
