Instruments and Amps Everything that makes music, Especially including instrument amps.
Replacing Burnt Components on Gallien Krueger RB400 Bass Amp
Old 20th February 2018, 12:50 AM   #31
Cheeto333 is offline Cheeto333
Hmm. Looking at the schematic, the rectifier inputs are the two blue wires (taps 3 and 5), which I measured as ~80VAC. Yes, it appears to be center-tapped, so these readings are expected, correct?
Old 20th February 2018, 02:04 AM   #32
As a note: the bulb did not glow brightly at 4 VAC on the variac, but more than I thought it should have.
Old 20th February 2018, 02:41 AM   #33
PRR is offline PRR  United States
PRR's Avatar
A 120V bulb can't glow at ALL with 4V from the Variac.
So you have something wrong, but we can't know what.
Old 20th February 2018, 03:16 AM   #34
Is it safe to connect the secondaries of the transformer one at a time until the bulb begins to glow? That might help isolate the issue.
Old 3rd March 2018, 01:31 PM   #35
thoglette is offline thoglette  Australia
thoglette's Avatar
Thought I'd posted this earlier.
Better to first disconnect the secondaries individually; disconnect and check the PSU electros. Then check secondaries with rectifiers and electros ONLY.
That will at least establish if your power supply is OK.
Old 17th April 2018, 12:01 PM   #36
thoglette's Avatar
Well, I'm guessing it all ended badly :-(
Replacing Burnt Components on Gallien Krueger RB400 Bass AmpHide this!Advertise here!
Gallien-Krueger Power Issue cwbassman Instruments and Amps 17 22nd August 2015 02:12 AM
need help with gallien krueger 800rb dkdeleon Instruments and Amps 19 3rd June 2010 09:27 PM
Gallien-Krueger 200MB Schematic keltonic Instruments and Amps 1 29th October 2008 10:21 PM
Gallien-Krueger schematics gardel Instruments and Amps 0 26th May 2008 02:24 PM
