Instruments and Amps Everything that makes music, Especially including instrument amps.
Valve tone stack work on solid state?
Old 16th January 2018, 02:19 AM   #11
PRR is offline PRR  United States
PRR's Avatar
That amp HAS a "Fender Twin tonestack" IN it.
Except all the values are different, and not all the same ratio. (If it was same-ratio the response would be unchanged.) And a minor difference in how the MID pot comes in, which only matters at extreme. The result does not look "wrong".
I'm not sure if djgibson's 850Hz is a mis-reading of those cap values, or may be real. Some of those caps do seem awful shy, but I hate that notation and the sloppy labeling. 13dB down at 85Hz is heavy bass-shave but *may* be appropriate for a small g-amp working with a bass player. (Don't compete for boom; sing higher than the bass.) It won't be impressive playing alone.
Valve tone stack work on solid state?Hide this!Advertise here!
How Solid State Amps Work badraven Solid State 35 22nd January 2013 01:47 PM
Making a solid state safe to work on when you can't reach the caps towerofmanpower Solid State 1 13th May 2010 06:04 AM
Cheap solid-state power supplies - would these work? Spasticteapot Planars & Exotics 7 18th December 2006 12:27 AM
Oil Filled Transformers Valve Filaments or Solid State Equipment mozfet Swap Meet 2 28th October 2002 07:22 PM
The Solid State Wiki - Your solid state reference guide Jason Solid State 0 25th June 2002 05:26 PM
