Instruments and Amps Everything that makes music, Especially including instrument amps.
Unknown AKG capsule (diy mic help)
Old 3rd January 2018, 03:42 PM   #1
hajko is offline hajko  Serbia
Default Unknown AKG capsule (diy mic help)
Hi, guys.
I found this capsule on line, but there's no info at all. It's akg ck40. It's 15mm x 6mm in diameter.
I already built a mic based on schoeps circuit (Zapnspark version) and i used J305 fet...it works ok, except a huge high frequencies boost. I will post images of disassembled capsule.
I tried to lower high frequencies by soldering 6.2nf or so...in parallel with drain resistor. It helped, but it needs more taming.
My question is...do i need to build a circuit with polarization voltage for the capsule...Would that help...and is this electret or condenser type?
Thanks.
Old 5th January 2018, 06:47 PM   #2
dotneck335 is offline dotneck335  United States
According to AKG data sheet, "CK" prefix indicates "Microphone capsule with condenser transducer"
therefore it must be polarized.
Unknown AKG capsule (diy mic help)Hide this!Advertise here!
Veco mic capsule steeven Parts 3 27th September 2017 05:26 PM
Capsule of condenser mic ChurritoTierno Everything Else 15 20th August 2017 05:55 AM
condeser capsule tmatini Parts 2 23rd May 2012 10:09 PM
what capsule to use in a diy measurement mic Sobo Multi-Way 1 24th October 2010 10:15 PM
Anyone have an extra electret capsule? Kilentra Swap Meet 2 3rd March 2004 05:57 AM
