Instruments and Amps Everything that makes music, Especially including instrument amps.
Jensen JT-11P-1 wiring help
Old 31st December 2017, 07:43 AM   #1
tyla is offline tyla
Default Jensen JT-11P-1 wiring help
Im building a passive guitar splitter with a Jensen JT-11P-1 transformer. I want phase reverse and ground lift. I think I got the signal and phase rev right with red+brn (primary) and yel+org secondary. But there is also a black and a white lead (grounds?) I donít know where to connect them and how to get the ground lift working. Your help would be appreciated. Thanks
Old 31st December 2017, 08:24 AM   #2
simon7000 is offline simon7000  United States
For now you can leave the black and white wires unconnected. They should be insulated from each other and everything else. The center of the ground lift switch goes to the input connector ground. Be sure to use standard phone plugs not insulated ones. Of course you need a metal case.
Old 31st December 2017, 08:48 AM   #3
I found this one. Looks like white is going to ground and black to output sleeve?
So with ground lift it would be something like this. Correct? But then when ground is connected I will also connect black with white. Is that bad?
Old 31st December 2017, 12:35 PM   #4
As shown will work. The black and white connect to foil inside the transformer to shield the windings. So when you don't ground lift it doesn't matter if they are connected.
What most folks don't know is there isn't much difference in performance if the leads are connected or not.
Jensen JT-11P-1 wiring helpHide this!Advertise here!
Wiring a line array: altering wiring schemes for matching levels w/woofer dave251 Multi-Way 6 5th February 2014 01:21 AM
Thiele/Small parameters for Jensen G-600 or Jensen P15LL. Marco Gilardetti Multi-Way 5 3rd January 2014 07:21 AM
FS: Jensen JT-11P-1 line transformer WTB/WTT: Jensen JT-DB-E jsmith1 Swap Meet 0 26th August 2011 11:06 PM
Focusing on wiring cable for gainclone!!!Share ur experience in wiring cable.... thomgun_lc Chip Amps 38 31st August 2005 02:46 PM
I'm wiring my 4 channel 8 parallel LM4780 boards... check my wiring :) Audiophilenoob Chip Amps 9 16th August 2005 04:37 AM
