Instruments and Amps Everything that makes music, Especially including instrument amps.
Hiwatt/Ampeg Clone
Hiwatt/Ampeg Clone
Old 14th June 2018, 12:15 PM   #41
blackwhaleamp is offline blackwhaleamp  Belgium
blackwhaleamp's Avatar
Originally Posted by gingertube View Post
Have you gone over the power rail bypass caps. A dodgy joint at either end of a single bypass cap could also cause that POC POC POC from the "motor boating" form of oscillation via feedback on the power rail.
Wow, thank for the tips. I will try your solution. Someone also suggested me that the issue might be motor boating. I change the 12AU7 stage to another cap, and the POC POC improved a lot. However, it keeps coming from time to time
P.S. Bothering with this cause I like your design, something I might build for myself "one day".
The difficult part was to find/make the toroÔdale. Those are hand made, and I am afraid that this could be another source for the issue. I don't have a machine to build those kind of transformers.
You can find how to make those here
Bass preamplifier in the Ampeg SVT tradition
The output impedance from the 12AU7 cathodes is going to be really low, approaching 1/gm, say some thing like 100 Ohms, so try a 220 Ohm series "build out" resistor in series with the feed to C14, C16. Not 100% sure of that 100 Ohms output impedance "butt pluck / err. educated estimate from insufficient data" - so try resistors up to not more than 1K5. If that doesn't fix, higher values wont either.
I put a 100 Ohm resistor between the C14/C16 and the Cathode and it fix the issue
Sometimes the POC POC POC comes back , but not very frequent. I have no more ideas about what to do. In any case, I'll deliver the amplifier as is. There is something that triggers that noise, and I have no idea what could it be.
Thanks for the support
Old Yesterday, 08:32 AM   #42
Default Yet another issue with Hiwatt replica
Hi
Here I come again asking for help for this Hiwatt replica that I build few months ago. There are the two threads that I received plenty of feedback to finalize the amp.
http://www.diyaudio.com/forums/instr...t-ampeg-4.html
http://www.diyaudio.com/forums/instr...att-ampeg.html
Few months ago I received the amplifier back because for some reason it starts to make a PUK PUK PUK noise. I added a video that shows the noise.
After looking for more info on the internet, I found out that it could be motor boating due to a defective decoupling cap on the power supply. I changed one of the two 100+100 uF cap. Maybe I need to change the second
I not sure if anyone can advise me what could I do.
Maybe changing the power supply itself, like adding another rectification stage.
Maybe someone has a layout of an original Hiwatt, it could be that I have a ground loop somewhere and it would be good to see how a real Hiwatt is cabled inside
Thank a lot for your help, this is the last step to complete this amplifier
Old Yesterday, 09:17 AM   #43
JonSnell Electronic is offline JonSnell Electronic  United Kingdom
JonSnell Electronic's Avatar
Motor-boating is caused by instability. Fit grid stoppers for parasitic noise and decoupling for motor-boating, also layout is extremely important.
I have a pdf of the layout but it is too large to upload.
I will pm it to you.
Try here;
Support for Fender, Marshall and all Valve Equipment; Audio Innovations, Audiorama FU29, Quad and Leak. www.jonsnell.co.uk
Old Yesterday, 10:10 AM   #44
avtech23 is offline avtech23  Australia
WAF. The most critical value in audio!
avtech23's Avatar
Hiwatt/Ampeg Clone
Not sure if it is just the recording audio, but it sounds like something arcing(?).
Have you checked all your solder connections are good? No accidental shorts? Resistors close to the valves all correct values?
A really thorough visual inspection should be your first step.
Check the continuity of the output transformer. I've heard of motorboating being caused by open circuit OPTs before, as well as defective cap.
Being built a few months ago, I assume the parts (capacitors and valves) are from good stock? Have a good look at the capacitors - any leakage?
Does it happen at all settings (volume etc)?
If competent around high voltage, check the behaviour of the voltages when the amp is making the noise - is there an area of the circuit where the voltage is dipping? Try to narrow down the search area.
The ever growing project list.. NAP140 Clone | NAD 3225PE | VSQC Phunk Style | NAD 3020i | 2 Princeton Clones | JLH1969 | Retro 50W (Last in line)...maybe
Old Yesterday, 10:30 AM   #45
jazbo8 is offline jazbo8
jazbo8's Avatar
Hiwatt/Ampeg Clone
@blackwhaleamp - It's against the Forum Rules to start multiple threads on the same topic, as a result, your threads have been merged.
Hiwatt/Ampeg CloneHide this!Advertise here!
Ampeg B15N Clone Guitar / Bass Amp john65b Swap Meet 4 3rd August 2017 03:34 PM
Sonus Faber Cremona HYBRID Clone raelman Multi-Way 108 11th June 2016 02:45 PM
Ampeg B-15 or Fender Bassman clone rebuild? andyjevans Instruments and Amps 9 25th January 2016 09:33 AM
Ampeg B15 Heritage Clone Help ElCucoArg Instruments and Amps 2 3rd May 2012 09:41 PM
JM Lab Utopia/Grande Hybrid clone pics SpeakerNut Multi-Way 0 11th February 2005 02:57 AM
