Instruments and Amps Everything that makes music, Especially including instrument amps.
Korg Triode for Guitar Preamp
Old 11th December 2017, 09:25 PM   #11
djgibson51 is offline djgibson51  New Zealand
Maybe a tube preamp for acoustic can be set up to add 2H, but no clipping.
Old 11th December 2017, 09:55 PM   #12
2 picoDumbs is offline 2 picoDumbs  Australia
2 picoDumbs's Avatar
I answered your question a while back.
It just depends on whether his current amp has enough gain (which is almost certainly yes).
You don't need to over think this.
"If you leave this point unattached to some circuitry, an ideal constant current source will emit a small lightning bolt which will travel until it connects to something." Nelson Pass
Old 12th December 2017, 12:38 AM   #13
Gnobuddy is online now Gnobuddy  Canada
It definitely can, but the thing is, the reason we usually want that extra 2nd harmonic distortion is to "sweeten" the ugly sounds that come out of a solid-body guitar pickup.
A lot of that ugliness is created by the magnetic pickup itself - the magnetic field around the pickup pole-pieces is not uniform, and the guitar string moving through this causes a heavily distorted signal to be generated in the guitar pickup.
A good acoustic guitar (or acoustic-electric) usually has a completely different type of pickup - either a piezo strip under the saddle, or a little microphone inside the guitar body, or both. These types of pickups don't produce the same harsh distortion that the conventional magnetic pickup does. In addition, the guitar body itself is designed to produce a pleasing sound via its wood and cavity resonances.
So IMO a decent acoustic-electric guitar sounds good if you just plug it into any generic low-distortion amplifier with a flat and wide-enough frequency response. Theres no real need for the amp to add "sweetening", the sound is already sweet!
As usual, this is just my opinion, based on just my ears and my brain. Others may or may not agree.
Worth mentioning: I have one guitar (a Takamine) that uses an actual valve (triode) in the built-in preamp. Takamine calls this design their "Cool Tube" preamp, and their stated intention was to remove some of that harsh "piezo quack" that you often read about in reviews of acoustic-electric guitars. So someone at Takamine did think that a wee bit of valve distortion could help improve the sound of an acoustic guitar...
Does it work? I don't know whether the valve is actually responsible, but that particular guitar does have a rather natural plugged-in sound (i.e. it sounds a lot like it does when unplugged).
I bought that guitar for an entirely different reason: it has steel strings but they are almost as widely spaced as a traditional classical nylon-string guitar. I have big fingers, and it's the only guitar I have that gives me enough room for fingerstyle playing.
-Gnobuddy
Old 12th December 2017, 07:04 AM   #14
DQ828 is offline DQ828  Australia
DQ828's Avatar
All sounds great to me, now I just need someone to do a GB on PCB for the Korg Triode
Old 12th December 2017, 07:21 AM   #15
Kay Pirinha is offline Kay Pirinha  Germany
I personally have had very good experience with a Silverface (CBS) Fender Twin Reverb as an amplifier for acoustic instruments. It is clean and very (!) loud. So I'd recommend something like that: 1st 7025 triode - Fender tone stack - 2nd 7025 triode etc.
Best regards!
"Bless you, Sister. May all your sons be bishops." (Brendan Behan)
Old 13th December 2017, 07:53 PM   #16
DQ828's Avatar
I am aiming at a preamp
Old 13th December 2017, 08:43 PM   #17
Ok. Omit that »etc.«
Best regards!
Old 13th December 2017, 08:44 PM   #18
Good chance this might become available in diyaudio store.
Ask Variac.
Old 14th December 2017, 08:06 AM   #19
jazbo8 is offline jazbo8
jazbo8's Avatar
If you don't want to wait, you can get the buffer PCB from Pete Millett: DIY PCB plus Tube - Buffer PCB using the Korg Nutube 6P1 | eBay
Old 14th December 2017, 08:15 AM   #20
DQ828's Avatar
Thanks, waitings not a big problem I have SO many things to get finished, just agreed to a barter with a lady from work, she gives me a new high quality matteress (which I need) and I build her a simple work table and chair from her bedframe which I dont need!
Korg Triode for Guitar PreampHide this!Advertise here!
B1 with Korg Triode Nelson Pass Pass Labs 86 16th December 2017 02:01 PM
2 X PIONEER CDJ-1000 MK3 PLAYER, Korg M3 88-Key Workstation / Sampler,Yamaha Korg holocoast Vendor's Bazaar 0 22nd August 2009 08:03 AM
2a3 Triode Guitar Amplifier 2a3geek Instruments and Amps 2 23rd November 2008 08:34 PM
Guitar Preamp = MIC Preamp = other preamp ,,are they all same? Paswa Instruments and Amps 1 12th March 2008 06:16 PM
Which triode is the best for preamp? dimitri Tubes / Valves 6 30th March 2004 06:36 PM
Copyright ©1999-2017 diyAudio
