Instruments and Amps Everything that makes music, Especially including instrument amps.
Silvertone 1474 amp
Silvertone 1474 amp
Old 26th November 2017, 01:10 AM   #1
DeathRex is offline DeathRex  United States
Default Silvertone 1474 amp
So dude brings a Sivertone 1474 to fix. It's all stock. It does kinda work except for 2 burnt resistors and the reverb. It has a piezo reverb that they don't make any more. I've been researching and researching, and everyone just says to match your old reverb with a new one. Since I can't, I decided to rewire the circuit for either a 6CG7 or 6N1P driving a 8FB2C1B since it had the highest impedance (1925Ohms in). The Ampeg Gemini 1 used a 6CG7 to drive a reverb tank, but they didn't say what the impedance was.
I don't want to add another tube, just remove the 2nd 12AX7 and put in a 6CG7 or 6N1P, both can get down to 6.5KOhms internal resistance, with the 6N1P giving me a lot more gain.
Will the MOD 8FB2C1B that I already have mate up with a 6CG7?
Top picture is the Ampeg, bottom is the Silvertone.
Old 27th November 2017, 12:50 AM   #2
PRR is offline PRR  United States
PRR's Avatar
Originally Posted by DeathRex View Post
....I don't want to add another tube...
SilverTone did the piezo because it saved a tube. Both Gain and Drive. I don't think you will get there, well, without a tube or equivalent amplifier.
Old 27th November 2017, 01:49 AM   #3
A 6N23P seems to be a closer impedance match. With it I could get a gain of 31 for the gain stage and 27 for the drive stage. With the original 12AX7, Sears got a gain of 64 for the drive stage and 31 for the gain stage, so I do believe my signal is just going to be halved.
I don't know how much is lost in the reverb, and I don't know if there is a difference in loss between the transducer and piezo reverbs.
Old 27th November 2017, 02:45 AM   #4
Enzo is offline Enzo  United States
If you want a tube drive for a high-Z pan input check out the Ampeg circuits. Like the VT-40.
That piezo reverb is utter junk. Even when working right, it has all the tone of a screen door spring.
I have in the past successfully repaired those by harvesting a piezo disc from a cheap tweeter, and modified the little clamps to suit the disc. (One side versus two sides connections) But for all my efforts I just wind up with the same junky reverb.
Old 7th December 2017, 10:46 PM   #5
Well I got the resistors and caps replaced. I replaced the reverb driver and gain with a 6N23P. The 6N23P has a Ri of about 3K at 9.34ma. It all does work, except I'm getting a small bandwidth through the reverb. From 1khz to 2.3khz I'm getting about 4 times more signal out than at 600hz or 6000hz. In that band I'm getting more signal than through the non reverb channel. Why is that?
Old 9th December 2017, 12:23 AM   #6
jjman is offline jjman  United States
"Small bandwidth thru the reverb" = "tone of a screen door spring"
Old 9th December 2017, 02:54 AM   #7
I got the reverb replaced with a MOD 8FB2C1B. Going by the Ampeg schematic I used a 0.47uf after the 6N23P driver, and am wondering if it's too small. I've been testing it to day and I found a 0.22uf cap on the input or output of the reverb does wonders, it increases 600hz while lowering 1Khz. But it also lowers 2.3Khz a lot. I've tried putting a pot in series with the 0.22uf cap and adjusting it, it helps, but very little. I've also tried a 6N1P, 6CG7, 6DT8, and 6BZ8, but it doesn't change the bandwidth.
Old 30th December 2017, 08:41 PM   #8
I've tried 3 different circuits (Gemini II with a 6GC7, 6N1P, 6DT8, 6N23P, and 6BQ8, a pentode driver using a 6GH8A, from a online schematic, and just a cathode follower using a 6U8) all of them gave me the same variations. I even tried a Zune HD music player, and got the same results, a dip at 600 Hz and a peak at 1KHz. So I did a test and put in a series of audio test tones at a fixed input and recorded the output of the MOD reverb tank.
With 5 volts in:
60Hz - 50mv out
200Hz - 30mv out
600Hz - 12mv out
1KHz - 60mv out
1.5KHz - 30mv out
2KHz - 20mv out
5KHz - 5mv out
All into a 100Kohm resistive load. This is not what I was expecting from a good reverb tank.
Old 31st December 2017, 05:26 AM   #9
PRR's Avatar
...put in a series of audio test tones at a fixed input and recorded the output of the MOD reverb tank.....
Reverb tanks are generally driven with a high impedance, semi constant current. Use a series resistor 10X the tank's nominal input impedance. That will slant the whole spectrum for better highs.
However the 600/1K dip/peak sure sounds like a poorly damped mechanical resonance. The "good" springs often have bits of foam, perhaps to damp such rings. I'd never thought the MOD series was supposed to be fine wine; more a lower price spread.
Old 31st December 2017, 05:13 PM   #10
I did put in a 10K pot in series with the output a couple of weeks ago. Played around with it, but it didn't seem to do anything. Since I tested the reverb with the pot at 0ohms, I turned it up to 10K and retested and used a audio oscillator that put out 20 volts to compensate.
Series resistance 0Ohms 10K
50Hz 3mv 2mv
200Hz 15mv 2.5mv
600Hz 17mv 2mv
1KHz 100mv 17mv
2KHz 10mv 3mv
5KHz 6mv 5mv
I did verify that the oscillator was putting out 20 volts on each frequency.
Silvertone 1474 ampHide this!Advertise here!
SilverTone 1474 First stage lots of Hissss? Freecrowder Instruments and Amps 4 31st October 2016 07:16 PM
Silvertone Organ Amp smoreland Instruments and Amps 26 6th May 2015 07:00 PM
Silvertone replacement speaker Ron E Instruments and Amps 3 29th May 2008 11:31 AM
Silvertone Organ Amp higbone Instruments and Amps 34 7th May 2008 01:45 PM
Silvertone Model 1472 Gunny Instruments and Amps 12 2nd February 2006 06:49 PM
