Instruments and Amps Everything that makes music, Especially including instrument amps.
Beefing up bass amp with 2 6AQ5 ...
Old 24th November 2017, 12:11 PM   #21
Printer2 is offline Printer2  Canada
Originally Posted by nauta View Post
The output power of an amp is based on the PT capabilities and the OT primary impedance. In the amp as it is, these parameters are set and there is nothing you can do about it.
The only way you might get a little more power is if the amp is cathode-biased and you change it to fixed-bias. This will make the amp more dynamic BUT may not increase useful output, since full-load is still the same.
You would be more successful changing the speaker complement and cabinet positions. Use two cabinets separated by a space and let psychoacoustics work for you.
Higher voltage with SS diodes and a tube that can use it into the impedance. Or if the OY has multiple taps for the output you can go up a step in impedance without SS diodes, or if the transformers can take it, with.
Old 24th November 2017, 04:59 PM   #22
AquaTarkus is offline AquaTarkus  Canada
AquaTarkus's Avatar
Originally Posted by Paul Munters View Post
...had some looks and thoughts. I think I follow a gradual approach.
1. Change to solid state rectifier. This will increase the B+ to 375 volt, and save on heater power.
2.a. If not change to a pair of EL84s - What output to expect with B+ =375? (JonSnell suggestion)
2.b. If not change to a pair of 6L6s, while watching temperature of power transformer.
You should be able to get 15W fairly clean from a pair of EL84s that way, possibly up to 20W with a little distortion. If this is a bass amp it doesn't need to have hifi distortion levels.
As has already been said, 6L6s are too big for relatively little benefit. Same goes for EL34s and KT77s. The fact that your transformers appear oversized is actually good for bass response.
Beefing up bass amp with 2 6AQ5 ...Hide this!Advertise here!
Beefing up the Blameless. 5th element Solid State 66 6th December 2010 11:08 PM
beefing up STUDIO SE phoenix87 Solid State 0 28th July 2010 06:00 AM
question about beefing up my monoblocks sorenj07 Tubes / Valves 0 19th November 2007 03:08 PM
Beefing up the power supply whitelabrat Tubes / Valves 9 16th November 2007 07:23 PM
Beefing up EL34 PP effindi Tubes / Valves 6 17th October 2003 06:38 AM
