Instruments and Amps Everything that makes music, Especially including instrument amps.
Spectra 30 T, bad socket.
Old 9th August 2017, 01:32 AM   #11
CapnDenny1 is offline CapnDenny1  United States
CapnDenny1's Avatar
I GOT YOU SUCKR!
Normal voltages on pin 5 of each tube. This is the bias voltage that sets the idle current through each tube.
Click the image to open in full size.IMG_1614 by Dennis Kelley, on Flickr
After about 10 minutes the one on the right started looking a little unsteady? And then it really went crazy.
Click the image to open in full size.IMG_1615 by Dennis Kelley, on Flickr
Not its now +23 volts! But it gets better, or worse I guess?
Click the image to open in full size.IMG_1616 by Dennis Kelley, on Flickr
OL or overload, means greater than +60V.
Click the image to open in full size.IMG_1620 by Dennis Kelley, on Flickr
So lets see the control grid wants -33 and the more positive the more current? I wonder what happens if you give it +60V or more? Ruined tube, ruined tube socket, blown output transformer.
So barring a short in the wires, it must be the coupling cap. The other side of those caps have maybe 250V on them, but it should block it entirely, but it doesnt. It did this and then just went back to -33V as if nothing happened? "What replate?" Its kind of unusual that it is intermittent, but I have seen caps do that too.
Old 9th August 2017, 04:00 PM   #12
danFrank is offline danFrank  United States
Yes, it's the coupling cap. Can you post a picture of the cap, I'd like to see what type/brand it is. Good job on the troubleshooting. I was wrong! I've never seen a leaky film cap, I have seen open film caps though. Hmm...
Old 9th August 2017, 04:51 PM   #13
CapnDenny1's Avatar
I think it is a metallized polyester
http://www.illinoiscapacitor.com/pdf...R%20series.pdf
It might be polyproplyene, but it looks the same.
Spectra 30 T, bad socket.Hide this!Advertise here!
Bad Tube Socket - symptoms and cure w5jag Tubelab 2 18th June 2015 06:38 PM
Bad capacitors. Bad design or bad caps? Hayden Parts 9 10th December 2014 06:38 AM
Regulated power supply using 30-0-30 EI core transforformer for Gaincore am dvijaydev46 Power Supplies 10 26th November 2013 04:33 PM
B&K Dyna-Quik 500 test socket 9A shows good tubes as Bad vadgewhisperer Tubes / Valves 4 15th April 2011 03:36 PM
Copyright ©1999-2017 diyAudio
