Input transformer for Shure M63 Input transformer for Shure M63 - diyAudio
Instruments and Amps Everything that makes music, Especially including instrument amps.
Old 11th January 2017, 07:19 PM   #1
hearforever is offline hearforever  United States
Default Input transformer for Shure M63
I bought a Shure M63 Audiomaster for cheap that has a Baxandall type EQ control. I'm using it with bass recorded direct from the line out of a mike pre that has an instrument low-z input.
Stock it has a high impedance 50k line input. I'm using the 600 ohm balanced output to my mixing board/audio interface. I'd like to add a balanced input. Could I use a 1:1 bridging line input transformer like the Jensen JT-11P-1 / Edcor WSM-11k-11k or should I be using a bridging transformer with a different turns ratio?
Here's the manual for the M63 with the relevant technical data-
http://cdn.shure.com/user_guide/uplo...pro_m63_ug.pdf
(schematic on last page of pdf)
Old 12th January 2017, 04:46 AM   #2
PRR is offline PRR  United States
PRR's Avatar
Why? Is it humming?
Lo-Z to hi-Z is normally a very happy interface condition.
Old 12th January 2017, 04:52 AM   #3
Sorry, I think I was a bit unclear.
I want to add a balanced input before the Audiomaster. The stock input is high impedance unbalanced.
Old 12th January 2017, 10:05 AM   #4
melodicol is offline melodicol  United Kingdom
found this for you, if you were not aware already. seems like what your looking for
ART Pro Audio
I'm not familiar with balanced line but always been a fan of ART.
Old 12th January 2017, 10:41 AM   #5
turk 182 is offline turk 182  Canada
could you clear up why you want to send a recorded bass track through the M63 then into your other mixer? that's two mixers or two gain stages, as long as the noise floor remains low i guess there would be no problem.
other then level of operation the M63 has balanced input i would run your recorded bass track through a 20 db pad and into any of the four mic inputs or buy the Art DI and just send it to your main mixer. is there a problem with the high/line level inputs on the Shure?
Old 12th January 2017, 01:50 PM   #6
simon7000 is offline simon7000  United States
Use a 10K to 10K transformer. Place a 12K resistor inside to properly terminate it, or if you have a square wave generator and oscilloscope you can use an RC network for the termination. Start with the resistor and change the series capacitor to get the best square wave response.
No need to get a premium transformer. But even with a cheapie pick one rated for 100mW or more.
Try a Triad TY141P
Old 19th January 2017, 08:17 PM   #7
The M63 is different than the M67. The M67 is a mic mixer/preamp with 4 balanced microphone inputs. The M63 has high impedance line input and is basically an EQ box. My chain while recording would be bass > direct input on mike preamp > M63 > line in on mixer > DAW
or to process sounds I've already recorded
DAW line out > M63 > line in on mixer > DAW
The mixer I have doubles as an audio interface (it has firewire out). I use the line ins to my DAW.
Thanks for the transformer tip!
Old 19th January 2017, 08:34 PM   #8
yup that has a Homer moment for me M63 and M67 definetly not the same doh!
Old 20th January 2017, 05:48 AM   #9
dotneck335 is offline dotneck335  United States
Best would be to just use a DI box (as melodicol suggested) into your mixer, using its tone controls. This will produce a better result than using that Shure M63.
Input transformer for Shure M63Hide this!Advertise here!
Transformer input for P-P geezertron Tubes / Valves 14 13th February 2015 10:51 PM
Shure PA185 into Shure x2u - Circuit help MWinther PA Systems 2 6th December 2013 04:49 PM
Shure M95HE and Shure M97HE stylus interchange ashok Analogue Source 0 28th October 2009 05:34 AM
Input transformer: floating input = distortion ErikdeBest Tubes / Valves 13 20th January 2009 09:36 AM
about input transformer day Tubes / Valves 2 15th August 2005 12:45 AM
Copyright ©1999-2017 diyAudio
