Instruments and Amps Everything that makes music, Especially including instrument amps.
Need a new output transformer, checkmate 50!
Old 11th January 2017, 12:54 AM   #11
jaredkaputkin is offline jaredkaputkin
think im going with the mercury magnetics tweed bandmaster output tranny. its not crazy expensive, and seems like the best i can get!
Old 11th January 2017, 03:20 AM   #12
Bob Richards is offline Bob Richards  United States
Bob Richards's Avatar
I'd go with the Fender brand, and use a replacement for any Fender amp that has 2 6L6GT output tubes AND supplies the 8 ohm output winding. I usually buy them from Antique Electronics in AZ. Fenders are less expensive than Hammonds, which are relatively inexpensive. Fender trannies have proved themselves in the field for years. I doubt if anyone would hear a difference or see a reliability difference compared to the Mercuries. I'd also add a 20 ohm 5 watt resistor in series with a 100nF polyprop cap, across the output, at the output connector, so supersonic energy (above the audio frequency range) generated during clipping (overdrive) doesn't cause the output tranny to generate transients that go over 1000 volts, due to the rising impedance of the speaker at those frequencies (for reliability). If the secondary of the transformer is mis-matched (8 ohm tap driving 50 ohms for ex.), the tranny starts to operate as a spark coil. 8 ohm speakers are not 8 ohms at 50kHZ. I've fixed guitar amps where these high voltage transients caused arcing at the tube sockets. This can be the cause of a blown output tranny, blown tubes and their sockets and even potentially a blown speaker.
Need a new output transformer, checkmate 50!Hide this!Advertise here!
want to make 50-0-50 5 ampere mains transformer ravslanka Parts 10 14th May 2016 11:50 AM
Priboi 50 YM 204C output transformer crazymechanic Parts 0 12th April 2016 09:26 AM
WTB Teisco Checkmate 30 amp galaxiex Swap Meet 2 18th September 2015 11:42 PM
teisco checkmate 15 no sound bagudan Instruments and Amps 14 19th March 2012 10:15 PM
teisco checkmate 15 no sound bagudan Instruments and Amps 3 5th March 2012 05:28 PM
Copyright ©1999-2017 diyAudio
