Looks like v47 is the only supplier now. Weber said cant get the frames.
V47 Speakers
Is the Boss BRS69 maybe useable? Has it been tested in instrument amp?
BRS69 - Boss Audio Systems
Its for a new design, a compact reverb valve hybrid-D head.
V47 Speakers
No, forget it:
* thick cone
* Large heavy voice coil
*******Polypropylene cone
* non ribbed cone
***** whizzer "passive tweeter" cone
what you need, if you find a working one, is an old dashboard or back seat 6x9" speaker, pulled from a late 60´s or early 70´s Ford Fairlane or similar age and build car, which only had an AM radio.
* thick cone
* non ribbed cone
I made several guitar amps using car stereo speakers in the mid to late 90's. All of them were tube amps, most were SE designs based on the Fender Champ, some with up to 15 watts using a KT88. The results were mixed. The old Jensen speakers with the blue foam surround sounded pretty good, but didn't live long. Some of the Audiovox two ways worked good and took everything I threw at them.
The amps that came later, around 2000, didn't have much "guitar amp" character. Car speakers had morphed into what they are today, huge magnets, heavy cones, lower efficiency, and blah sound. Of course you will never blow one since they are made to withstand the onslaught of the multi jiggowatt car amps playing bass heavy thumpa - thumpa music.
I haven't tried a car speaker in a guitar amp in years, but I can imagine that they have only gotten worse.
Found one more , closer to requirement.
http://www.parts-express.com/pedocs/specs/264-836-tang-band-specifications-45160.pdf
Unfortunately Parts Express lists that driver as "no longer available"
Tang Band W69-1213SB 6"x9" Neodymium Woofer
yes I saw it later so went to tb and took a look. There are three 6x9 , two have paper cones.
they are pricey though.
The truncated frame is great for a head.
W69-1213SB - 6x9" Paper Woofer - TB SPEAKER CO., LTD.
I don't know what size box you are looking at, but I made a cabinet for smallish guitar amps, two of them actually. They use these drivers from PE:
Dayton Audio PA165-8 6" PA Driver Speaker
Each box has a pair of the 6 inch speakers wired in parallel for a 4 ohm load. This will extract maximum power from the TPA3116. I have them in a 1.2 cubic foot box with a 2 inch by 3 inch square port (no tube or duct) This gives a reasonably flat response down to 80 Hz or so. I added a horn tweeter on a switch. It's turned off for cranked distorted guitar, but on for keyboards because it adds realism to a digital piano. These cabinets have survived some serious torture from a 100+ watt tube head feeding both cabinets, no issues.
I don't have any decent pictures, but one of them is seen here during the development of a $50 2 watt amp head.
Jfetter
You may be interested in these. I'm not associated with this business, but have been thinking about the 6 or the 6x9.
Classic Car Speakers
Terry
Terry
I used a pair of the factory 4" x 6" speakers from my 97 ford F150 to make a small practice amp and they sound great - the 'head' is the amp from a pair of computer speakers and a zoom g1xon for effects.
Yep I suspect they sound 'better' no standing wave from round.
I just noticed this is available in Nd 4 ohm no wizzer !
Perfect for tpa311x but have to power limit.
The hybrid stealth speaker head is saved.
The old Ted Weber Co has made them available again. Nice to see these back.
4,8,or 16 ohm 20W. Its just basic physics, a round speaker has weird artifacts such as cone imbalance harmonics. IMO non-round is better.
6x9" - Vintage Series - Speakers
Still interested in this thread ��
Here is the a product that uses the new Weber. I have no connection with this company.
White - Producer Model – echoparkinstruments
- Live Sound
- Instruments and Amps
- 6x9 instrument speakers almost extinct
