Instruments and Amps Everything that makes music, Especially including instrument amps.
Simple Passive 3 Band EQ with Sweepable Midrange
Old 26th March 2016, 01:33 AM   #1
garybdmd is offline garybdmd  United States
Default Simple Passive 3 Band EQ with Sweepable Midrange
Hi all, I wanted to get any thoughts or suggestions about this circuit I made. It has an input and output impedance of 1k and 1k, so it works ok with mp3 player/phone to auxillary input in car, etc (10k input impedance). I also multiplied all the resistors by 100 and divided all capacitors by 100 and used it in a guitar distortion preamp pedal. The midrange sweep is a bridged t filter, and as the frequency increases, so does the q but the notch depth decreases. Practically speaking, it does seem to have utility as it will sweep a fair amount of the midrange even though its simple. Has anyone seen this used? My goals were to make the simplest passive 3 band with mid sweep. I also wanted the very low loss when all knobs dialed up.
I also put directions on how to make one without as much bass loss, published on page: Page not found - Gary Davenport Electronics
Thanks all for looking and suggestions.
File Type: png Bridged T Model B 3 Band EQ with Simplest Sweepable MID.png (379.4 KB, 130 views)
Old 8th February 2018, 12:15 PM   #2
curlewcat is offline curlewcat
Hi Gary,
I've been searching for info on super simple sweepable eq, not much around.
This looks perfect for me, I need to remove a 2.2Khz peak from my violins valve amp.
I see it's no longer on your website, did it work ok in the long run?
Why did you us a bridged T instead of twin T?
Simple Passive 3 Band EQ with Sweepable MidrangeHide this!Advertise here!
Digital EQ Vs. Passive Xo EQ Tyimo Multi-Way 4 12th January 2014 06:08 PM
mec 3 band eq kendarmstat Instruments and Amps 3 2nd May 2011 01:59 AM
3 band eq kendarmstat Analog Line Level 0 3rd April 2011 02:56 PM
Ideas for a simple passive band-stop filter? oddbjorn Analog Line Level 8 18th January 2011 02:43 PM
Passive EQ to active EQ Nuuk Multi-Way 13 24th May 2004 07:59 AM
