Instruments and Amps Everything that makes music, Especially including instrument amps.
unhealthy idling pt load with only htrs
Old 20th November 2015, 12:56 AM   #1
hewo is offline hewo  United States
Default unhealthy idling pt load with only htrs
5f1 pt idling on htrs alone unhealthy?
Ckt has secondary ht ac out on open ckt switch, equiv standby.
Question is whether htrs alone drawing pt energy suffices enough load to not detriment pt on inadequate loading. Realize ht pt secondary switch is dpdt center off, as there's two secondary ht winding taps, one is 300, the next 330, dunno why, but both produce sound, 330 cleaner, 5f1 chromed chassis china diy kit
Old 20th November 2015, 01:08 AM   #2
Enzo is online now Enzo  United States
Here is the 5F1 schematic for anyone needing it:
http://bmamps.com/Schematics/fender/champ_5f1_schem.pdf
Old 20th November 2015, 02:22 AM   #3
Default further details
music-electronics-forum.com/t40815/
Old 20th November 2015, 02:27 AM   #4
Default link again
Http://music-electronics-forum.com/t40815/
Old 20th November 2015, 05:26 AM   #5
ErikdeBest is offline ErikdeBest  Switzerland
Did you get one of these keyboards without vowels?
I can't understand your question
my surname is indeed 'de Best': neither misspelling nor snobbism! Ask SY!
Old 20th November 2015, 11:43 AM   #6
Default illegal operation pt without secondary load applied
Android kybd, galaxy s3
Old 20th November 2015, 12:33 PM   #7
JonSnell Electronic is online now JonSnell Electronic  United Kingdom
JonSnell Electronic's Avatar
You will get offered answers a lot faster if you use English and not text speak. Most experienced engineers have no idea what text speak means!
Support for Fender, Marshall and all Valve Equipment; Audio Innovations, Audiorama FU29, Quad and Leak. www.jonsnell.co.uk
Old 20th November 2015, 02:01 PM   #8
20to20 is offline 20to20  United States
20to20's Avatar
Comp kybd cn typ lk tht 2. ? U pst w/BS phn kbd? U spnd 2 mch $$ 4 svc now must uz. 2 bad 4U butt it hertz our IIs.
Old 20th November 2015, 03:59 PM   #9
kevinkr's Avatar
It's also in the wrong place, this clearly belongs in Instruments and Amps.
"To argue with a person who has renounced the use of reason is like administering medicine to the dead." - Thomas Paine
Old 20th November 2015, 04:01 PM   #10
kevinkr's Avatar
I'd say writing in clear English could only help, best I can figure you are asking if running the transformer with only heaters drawing current from it was bad for it. The answer to that is no, not a problem.
unhealthy idling pt load with only htrsHide this!Advertise here!
Idling current in Rega Mira 1, 2 or 3 2N6658 Solid State 5 17th March 2012 04:05 AM
idling adjustment not possible tojoko Solid State 3 22nd February 2012 01:36 PM
1st build; Adding load to PT secondary cancon Tubes / Valves 33 31st October 2011 03:55 AM
Can anyone ID this rather unhealthy noise coming from my amp? SatinMill Solid State 20 26th October 2011 04:49 PM
Yamah p2200 setting idling current priscared Solid State 11 14th August 2004 01:39 AM
Copyright ©1999-2017 diyAudio
