Instruments and Amps Everything that makes music, Especially including instrument amps.
Need a good 8" guitar amp speaker
Old 13th August 2015, 02:27 AM   #1
LATUBEGEEK is offline LATUBEGEEK  United States
LATUBEGEEK's Avatar
Default Need a good 8" guitar amp speaker
I like building amps, not cabinets. And didn't think too much about speakers until I put (what I thought) was a great Fender Princeton clone I'd built into a combo cab with some new inexpensive 8" speakers. "Brand new, should sound great!" I thought. Was I wrong. Luckily, I plugged the amp into a Bugera 2x12 cab I'd bought cheap (less amp), and it sounded KILLER. But that cab was rated for 100W, and I had other plans for it. And I can't fit even 10"-ers in the amp with my Princeton clone. I need suggestions on 8" speakers that don't cost $80 or more, but will give me a good guitar sound. Cabinet was a Crate chorus SS amp, open back. Any ideas? Thanks
Old 13th August 2015, 04:17 AM   #2
Sonce is offline Sonce  Macedonia
Use only REAL guitar speakers: Celestion Eight 15, Jensen C8R or Eminence 820H, but you have to hear them first. Every guitar loudspeaker is a musical instrument on his own and creates a different sound. Jensen C8R is smooth and bright, for example.
Old 13th August 2015, 08:28 PM   #3
scrimpu is offline scrimpu  United States
If you opt for the Jensen go vintage. Much sweeter than the new stuff.
Old 13th August 2015, 08:48 PM   #4
nigelwright7557 is offline nigelwright7557  United Kingdom
nigelwright7557's Avatar
You could use an extension cab to put in bigger speakers.
I used to work for a mobile disco where all the guy who built it used was 6 inch speakers.
But he had about 20 in each box !
It didn't sound bad at all, maybe a little bass light but fine otherwise.
Murton-Pike Systems PCBCAD51 pcb design software. http://www.murtonpikesystems.co.uk
Old 13th August 2015, 09:03 PM   #5
mcandmar is offline mcandmar
Interested in this too as i built a priceton clone with a cheap as chips Jensen Mod 8" speaker. Big mistake as it sounds like a cheap paper speaker, just meh.
Old 13th August 2015, 11:18 PM   #6
diyAudio Member RIP
The Jensen Mod 8 is ideal for open backed, but has no presence peak.
rgds, sreten.
Old 14th August 2015, 04:43 AM   #7
JMFahey is offline JMFahey  Argentina
JMFahey's Avatar
Another positive vote for the Jensen MOD 8 , killer speaker.
Low price is just a bonus but makes many dislike them, I mean those who listen with their wallets.
Compare it to other 8" guitar and it works fine, definitely in the same league .
Compare it to a 12" V30 or similar and it will seem weak .... like all the other guitar 8" speakers mentioned, by the way.
Compare pears to pears and oranges to oranges.
As a side note, found the
comment very funny
Should it be made out of Plutonium or something?
FWIW 99.99% of speakers (and 100% of guitar ones) are still being made out of paper, I wonder why
Old 14th August 2015, 12:31 PM   #8
LATUBEGEEK's Avatar
Great info thanks! I also have a Champ clone (my first build) with a (again) lame speaker in it, thinkng of buying two different speakers, try them in it first. You don't have to put matching speakers in a 2x8 com o cab, right? And I read about the "mid scoop" in guitar speakers. My Champ has no tome controls. Can you build a simple tone stack the adjusts mids only? Could make the speaker sound better....?
Old 14th August 2015, 03:52 PM   #9
No! They must be identical.
Old 14th August 2015, 06:26 PM   #10
voltwide is offline voltwide  Ireland
You forgot the Eminence Cannabis Rex
Need a good 8" guitar amp speakerHide this!Advertise here!
looking for a good/great guitar speaker. 60ndown Instruments and Amps 9 22nd August 2012 04:53 PM
"REPLACE YOUR GUITAR AMP TUBES WITH THD "Yellow Jackets" NO REBIAS NEEDED. JUST PLUG cbdb Instruments and Amps 2 14th March 2012 05:49 PM
"Good" quality in-ceiling speaker supplier from china swak Multi-Way 0 23rd February 2009 07:43 PM
12" "guitar" driver in Audio Speakers jwhit67 Multi-Way 4 11th February 2008 02:47 PM
Copyright ©1999-2017 diyAudio
