Instruments and Amps Everything that makes music, Especially including instrument amps.
1982 Fender Concert II - low volume?
Old 11th July 2015, 07:34 PM   #1
cancon is offline cancon  Canada
Default 1982 Fender Concert II - low volume?
I've got a Rivera-era Fender Concert on the bench.
I've rebuilt the rectifier circuit and swapped out all the old Mallory electrolytics. All the important resistors check out OK and the main board caps are all orange drops which I don't believe need replacing. All the tubes have been tested, V1, phase inverter are new, and the output 6L6 set has been replaced and biased.
I think the amp sounds great, the 2nd channel is plenty loud. But, as it was when it arrived, I was surprised to see the first channel volume needing to be pushed up to 7 to be as loud as a 60s/70s era Fender set to 3. Is this normal?
The voltages on V1 and V2B are approx 200V on the plates and my test signal voltages corresponds to the mVac specs listed on the schematic at those tubes.
Thanks in advance!
Old 11th July 2015, 07:55 PM   #2
JonSnell Electronic is offline JonSnell Electronic  United Kingdom
JonSnell Electronic's Avatar
I would follow the stated signal path on the manual and watch the the levels. That will tell you straight away if there is an issue.
Support for Fender, Marshall and all Valve Equipment; Audio Innovations, Audiorama FU29, Quad and Leak. www.jonsnell.co.uk
Old 12th July 2015, 05:22 AM   #3
I followed the service manual notes - all controls on max, boost off, with 1kHz @ 4mV rms. My measurements match the listed values.
I don't have as much experience with 80's+ circuits, I'm not sure if it's normal for the first channel to be so quiet v.s. a deluxe reverb (RI or not) at the same settings. If any other 80s Concert owners are reading this, please chime in!
Old 12th July 2015, 10:12 AM   #4
If the measurements are correct, then that is that. Must be a reason for it as that is how it was designed.
Old 13th July 2015, 03:00 AM   #5
boobtube is offline boobtube  United States
I don't know how much of a holdover the characteristics of those Rivera amps were compared to the red knob series but I had a red knob Super 112 and I had the same number differences as you had. Really nice cleans, as good as it gets but had to have it on 7 to be loud enough to cut through the mix.
There is quite a bit more output when overdriven to distortion so that could be a large part of it.
1982 Fender Concert II - low volume?Hide this!Advertise here!
Plates glowing on my Fender Concert after blowing fuse nooel Instruments and Amps 63 1st August 2011 07:44 AM
Fender champ circuit low output. Jayoldstuff Instruments and Amps 6 27th March 2011 07:58 PM
Fender Blender volume mod Picky Nancy Instruments and Amps 0 2nd August 2009 11:54 PM
Adding a master volume to a Fender 5C3 Deluxe bereanbill Instruments and Amps 6 29th March 2009 06:30 PM
