Instruments and Amps Everything that makes music, Especially including instrument amps.
Princeton clone hums - analyze my build?
Old 7th June 2014, 11:41 PM   #1
LATUBEGEEK is offline LATUBEGEEK  United States
LATUBEGEEK's Avatar
Default Princeton clone hums - analyze my build?
Attached is the belly of my 2nd ever build. Completed earlier this year, but have gone back to it to change a few things. Biggest is some hum. I want this dead quiet! I know I have a lot to learn about proper grounding techniques, so I'm spilling my amps' guts out for you guys.... About my notes: All ground points are underlined in "pink"; eyelet board layout is (from left): preamp/DC caps/phase inverter/(some open space)/tremolo section. Questions: Should I twist the green filament wiring? Should the input jack be insulated from the chassis? The tremelo ground wire is long, goes to the phase inverter ground point (lug to eyelet board mount stud). I tried to keep each "section" a separate ground, and the guitar input at the far end of the board, away from the electrolytics. Appreciate all critique and suggestions! P.S. There is a pwr tube bias pot next to the spkr jack; and there is no tone stack in the build (yet) - just put a pot in there for later. Thanks!
Old 8th June 2014, 12:32 AM   #2
nigelwright7557 is offline nigelwright7557  United Kingdom
nigelwright7557's Avatar
The heater wires need twisting.
Try to run heater wires away from signal wires.
After that you need a star ground system with a single connection point at the power supply.
Try to separate the power supply ground. The charging pulses into the smoothing capacitors can modulate the ground line and cause serious hum.
A couple of years back I designed a mixer and just the laid the pcb out the way it came from the schematic. When I powered it up I had 1 volt of hum on the output !!!
I realised the power supply charging pulses were in with the signal ground and was modulating it.
So I redesigned the pcb with the smoothing ground going to the edge of the pcb where the power ground came in. This time I got pretty much zero hum.
PCBCAD51 pcb design software. 2018 version out now with lower prices >> http://www.murtonpikesystems.co.uk
Old 8th June 2014, 02:14 AM   #3
LATUBEGEEK's Avatar
I just redid the heater wires - see attached. No change.... Will make sure the power supply ground(s) are all by themselves. And should this point be as far away from other ground points as possible (and keeping lead length to a minimum)? Thanks!
Old 8th June 2014, 05:55 AM   #4
djgibson51 is offline djgibson51  New Zealand
Go to the valvewizard's site. Read the section on grounding.
Old 9th June 2014, 02:35 AM   #5
LATUBEGEEK's Avatar
Just read thru the Valvewizard write-up, and WOW was I doing things wrong....using the chassis as a ground plane, willy-nilly grounding, and with the PT secondary center-taps grounded as well... Ouch! I'm gonna lift the whole circuit off the chassis - including input & spkr jacks - totally floating, and connect the circuit ground busses ala fig 15.5b (to minimize ground loops within the circuit). Hoping for amazing results! Thanks!
Old 23rd June 2014, 06:25 AM   #6
costis_n is offline costis_n  Greece
You still must ground 2 points to the chassis. The mains earth (green cable) and the input jack (maybe through 2 antiparallel diodes)
Old 23rd June 2014, 09:47 PM   #7
LATUBEGEEK's Avatar
Costis - this is for electrical safety sake? Chassis to earth, guitar to chassis (to earth)? Makes sense. Thanks
Old 23rd June 2014, 11:03 PM   #8
famousmockingbird is offline famousmockingbird  United States
Yes it is for safety. If you enclose anything electrical in a metal box, the box must be connected to safety ground in the event of something shorting to the box. This is especially important with instrument amplifiers because the musician is usually in contact with the chassis via the strings of the guitar.
As far as using a ground bus care is still taken to keep larger currents away from sensitive input stage currents, meaning you can still get loops. A star ground is yet a better way to do grounding.
Old 24th June 2014, 12:24 AM   #9
Enzo is offline Enzo  United States
And be aware there are many sources of hum that have zero to do with grounding.
Heater to cathode current for example.
Determine if you have 60Hz or 120Hz hum, or both. They come from different sources.
Old 24th June 2014, 12:31 AM   #10
60Hz is from heater supply or magnetic coupling from transformers.
120Hz is from poorly smoothed supply.
I had an interesting fault on a mixer pcb.
If I cascaded 2 stages in the same valve there was no hum.
If I cascaded 2 stages across different valves there was hum.
It seems the 2 stages inside the same valve had hum which was cancelling !
In the end the hum was coming from a too close transformer.
It wasn't the heaters as I checked with a DC heater supply and the 50 Hz hum was still there.
Princeton clone hums - analyze my build?Hide this!Advertise here!
Princeton 5F2A Scratch Build Debo Construction Tips 3 15th November 2012 08:53 PM
What to build after Clone 2.5? zdr Multi-Way 17 13th March 2008 02:44 PM
Next amp build - Trainwreck - Princeton - Deluxe ??? gtrbryan Tubes / Valves 9 15th October 2006 06:07 PM
My Fender Princeton FD2 chasis (clone) elementx Instruments and Amps 5 7th June 2006 11:53 PM
Fender princeton/champ clone layt Instruments and Amps 6 24th April 2005 06:47 AM
