Instruments and Amps Everything that makes music, Especially including instrument amps.
Powered Speaker - Lo-Z Balanced Input?
Old 14th March 2014, 01:28 PM   #1
JayZ is offline JayZ  Canada
Default Powered Speaker - Lo-Z Balanced Input?
I have several Chinese clones of a JBL EON 15 G2 powered portable PA speakers made by "Naphon". (see pic attached). I don't have a schematic and Naphon can't provide me one. The input is 1/4" . I'd like to determine if the input will take a lo-z balanced TRS input. I can open up the amp and look but the presence of TRS connections may only be for "stereo" input purposes. Is there something I can measure with my DMM or look for that would help me determine if it is a lo-z balanced input?
Thanks.
Old 14th March 2014, 02:57 PM   #2
JonSnell Electronic is offline JonSnell Electronic  United Kingdom
JonSnell Electronic's Avatar
If it has a TRS socket, that will be balanced. I am surprised that there is no XLR input like the JBL's have. There will be noise heard from the ring of a TRS plug as there will be from the tip, if it is balanced.
Support for Fender, Marshall and all Valve Equipment; Audio Innovations, Audiorama FU29, Quad and Leak. www.jonsnell.co.uk
Old 16th March 2014, 11:36 PM   #3
There are two input jacks; "Left and Main-Right". Only the right produces any speaker output no matter what the "Balance" control is set to. But very strange design. BTW - the main board is labelled "KS 153A". I googled it but couldn't find anything relevant. Each 1/4 female input jack is wired as mono although they are TRS ready. I opened it up and changed some connections around so that it seems to work fine feeding from the balanced mixer output. I decided to try to wire the "right" to Tip and "left" to Ring. That seemed to work although I have no idea whether I actually have a balanced line or simply unbalanced with an extra line. (Is there a way to measure with a DMM to see if it is balanced?) I'm speculating that a Chinese "engineer" may have been trying to copy the design from JBL or EV or etc. and mis-labelled what they found.
Anyway, I didn't see smoke or hear distortion so I'll modify the other units I have in the same manner. Thanks for your suggestions.
Powered Speaker - Lo-Z Balanced Input?Hide this!Advertise here!
Balanced input test jig for speaker testing tvrgeek Equipment & Tools 6 3rd March 2013 08:56 PM
RCA Lo to Speaker Hi imputs & will this work Jraldi Construction Tips 6 2nd April 2011 04:09 PM
DC powered active Xover w/ balanced outputs? AudioBike Analog Line Level 8 12th November 2009 05:11 PM
DIY lo-fi speaker element Mursu Multi-Way 15 29th March 2009 03:44 PM
Balanced+Phantom powered Guitar Pre-amp RonNovy Instruments and Amps 2 22nd May 2008 09:32 PM
