Instruments and Amps Everything that makes music, Especially including instrument amps.
Bias a triode cathode negative for more gain?
Old 24th February 2014, 03:53 AM   #1
LATUBEGEEK is offline LATUBEGEEK  United States
LATUBEGEEK's Avatar
Default Bias a triode cathode negative for more gain?
What if....you had less B+ than you wanted, so instead of grounding the cathode, pull it negative to ground with a "B-" supply (like is done with fixed-bias power tubes)? Only takes a diode, a filter cap, and a resistor to control it. Then of course bias the grid even more negative... you could make 90V on the plate look like twice that! Anyone every needed to try this?
Old 24th February 2014, 06:06 AM   #2
Ceglar is offline Ceglar  Australia
Banned
I tried it with a split rail supply like that, actually I like it because you can juggle it so that the plate voltage of that stage is equal to the bias voltage of the next stage, you can DC couple this way without the need for any RC in the cathode of that next stage because its cathode is at 0V. You will need to provide some DC blocking for whatever is feeding the first stage because its grid won't be at 0V. Transformer works well.. some really nice mic. transformers for low level application, small, shielded and not too expensive.
Old 24th February 2014, 04:12 PM   #3
kuroguy is offline kuroguy  Germany
kuroguy's Avatar
isn't pulling the cathode negative wrt ground the same thing as raising the B+ and moving the ground reference? we are, after all, just talking about relative voltage levels regardless of the application.
"The magnet wire used to come from Radio Shack. In keeping with their policy of figuring out what the best products are and discontinuing them they no longer have it." - Max Robinson
Old 24th February 2014, 04:39 PM   #4
LATUBEGEEK's Avatar
Kuroguy: Yes it is the same, but if you don't have the B+, how can you increase the relative voltage levels (difference)? Go below ground, with a negative rail (sorta like OP amps use?). I only have 117VAC, want 150VDC or more on a triode preamp plate (without resorting to voltage supply doublers, etc.
Old 24th February 2014, 05:41 PM   #5
kuroguy's Avatar
call it what you want. take that negative 33 volts (117-150) that you have connected to the cathode which requires a change in the bias resistor and add it to the anode and you're at the exact same 150 volts without messing with the bias resistor.
Old 24th February 2014, 06:09 PM   #6
DF96 is offline DF96  England
Two options: add a negative supply; use a voltage doubler PSU. Both of these are essentially the same circuit - it just depends which point you ground.
Old 25th February 2014, 01:29 AM   #7
LATUBEGEEK's Avatar
Thanks for all the feedback - looks like it could work, whether it be a negative supply or voltage doubler. Will definitely look into later...I'm dying to put a tremelo on this amp, which will be a learning process in itself. I have Fender, Gregory and Weber circuits (both tube and SS) to compare and adapt, to "wobble" the preamp plate voltage.
Old 25th February 2014, 10:18 AM   #8
teemuk is offline teemuk  Finland
Could there be issues from the negative power supply having to sink too much current?
Old 26th February 2014, 12:31 AM   #9
Banned
Some of things that change when using a split rail supply are heater to cathode potential and DC grid voltage. The tube biases the same way, in that its the difference between cathode and grid voltage that sets the plate current for the stage, so using a split rail supply (all else the same) doesn't actually change the bias of the tube.
Old 24th September 2016, 10:51 PM   #10
stocktrader200 is offline stocktrader200  Canada
you'll have to filter the neg supply real good if your signal is referenced to ground.
ran into this when placing tube preamp into SX 3700 to test.
better to use a voltage tripler for B+ and reference all signal to ground.
The input transformer may allow you to be ok
Bias a triode cathode negative for more gain?Hide this!Advertise here!
Triode connected Pentodes in a cathode bias? leadfootdriver Tubes / Valves 4 3rd September 2009 11:11 PM
300B Cathode Feedback + Cathode Bias korneluk Tubes / Valves 13 7th January 2009 09:07 PM
Cathode bias 6LU8 UL/Triode mashaffer Tubes / Valves 2 29th September 2008 11:37 AM
Cathode bias 6LU8 UL/Triode mashaffer Tubes / Valves 0 29th September 2008 12:45 AM
UL to triode mode conversion on cathode bias amp-different cathode resistors needed? bigwill Tubes / Valves 6 30th December 2007 01:37 AM
Copyright ©1999-2017 diyAudio
