Instruments and Amps Everything that makes music, Especially including instrument amps.
A technical triode preamp question
Old 22nd February 2014, 03:02 AM   #11
LATUBEGEEK is offline LATUBEGEEK  United States
LATUBEGEEK's Avatar
The low plate voltages of this circuit is exasperating me! A B+ of 108VDC and plate current of 108/470K= 0.11 mA is barely even on the plate graph for a 12AT6.... How does this tube even work?? Has anyone written anything about this realm of tube application?
Old 22nd February 2014, 09:42 AM   #12
jazbo8 is offline jazbo8
jazbo8's Avatar
See the other thread, you need to change the B+ voltage drop resistor to a much smaller value (plus a bypass capacitor say 20uF) , and add a plate resistor.
Old 22nd February 2014, 03:11 PM   #13
DF96 is online now DF96  England
To run at low voltages you need low mu valves. 12AT6 has mu=70, far too high.
Old 22nd February 2014, 07:11 PM   #14
LATUBEGEEK's Avatar
The 12AT6 was in the intercom originally.....I'd hook you up with the original designer, but he's probably dead (RIP)....I added a 12AU7 (low mu), but have a 12BH7A, with a Mu of 16.5... may try it instead. Don't have many other 7pin tubes (other than a matched pair of 6V6 clone 6AQ5A's that I'm dying to push-pull for 10 watts, but that's a future project!).
Old 23rd February 2014, 04:58 AM   #15
jazbo8's Avatar
I think DF96 was just mentioning IF you want to run at low voltage, but there is really no reason to run any of the tubes at low voltage, when you are converting it the intercom to a guitar amp.
Old 23rd February 2014, 12:58 PM   #16
kuroguy is offline kuroguy  Germany
kuroguy's Avatar
Go to your local hamfest. 7 pin tubes are a buck a peice all day long.
"The magnet wire used to come from Radio Shack. In keeping with their policy of figuring out what the best products are and discontinuing them they no longer have it." - Max Robinson
Old 23rd February 2014, 05:04 PM   #17
LATUBEGEEK's Avatar
Thanks all for the info and suggestions. I'm just wanting to understand how tubes work at low voltages (there are plenty of vintage stuff that had them). Am finding out not that desireable...., but is still good to explore and learn.
A technical triode preamp questionHide this!Advertise here!
F2J technical question oon_the_kid Pass Labs 11 29th February 2012 11:58 AM
Mic preamp and high/low impedance technical question dewasiuk Analog Line Level 8 14th December 2011 01:47 AM
Technical question about heat. farmerjack61 Solid State 15 8th March 2011 01:36 AM
AD1862 interfacing - technical question Painkiller Digital Source 2 1st February 2011 06:59 AM
technical noise measurement question cuibono Equipment & Tools 26 4th November 2009 02:55 PM
