Instruments and Amps Everything that makes music, Especially including instrument amps.
Pentode pre/compressor (warning nube attempt at circuit drafting) --suppressor grid
Old 6th March 2014, 04:02 PM   #21
Blue Jinn is offline Blue Jinn  United States
Originally Posted by smoking-amp View Post
You might want a small cap from screen grid to cathode on the 6GY6 or whatever to hold the Vg2 constant. The high value screen grid resistor is commonly used to drop the voltage from B+, but it doesn't hold Vg2 constant against current change unless the signal is really small.
If there is a resistor from B+ to screen would that capacitor bypass the resistor and go to cathode or to ground? Also, from what I've read so far, it seems a regulated screen voltage from the PSU is preferred to a dropping resistor off the B+. The latter is easier though, and I'm not seeing the difference in something like this.
I'm not on Facebook. www.bluejinn.org
Old 6th March 2014, 04:23 PM   #22
smoking-amp is offline smoking-amp  United States
smoking-amp's Avatar
A cap from screen to cathode would maintain the most gain. Going to ground would provide a little neg. feedback ( cathode degeneration from resistance there). A regulated screen supply is good for output stages due to the larger current draw and for idle current stability with fixed (regulated) bias. With cathode resistor bias on this small signal stage, the resistor from B+ should work fine. You want the voltages to all track to keep idle current stable.
Old 6th March 2014, 07:20 PM   #23
Do you think this is worth breadboarding or is it not worth the effort, as too narrow a compression ratio to be useful? This really is my first foray into any kind of design, and is new territory for me. One of PRR's criticism was how much gain reduction do you want? And to quote
IMHO the 6BA6 is not the ideal audio squasher; that has not been designed yet (and never will be).
However, IIRC the Dolby A is only a 2:1 ratio and there is a mod to the CAT-22 card to use it to good effect. (But eliminates some lower bands to get the desired effect) Although then you have the noise/distortion problem with this one.
Don't see where I need a whole lot of gain for a compressor in this instance, as it would likely be used from a line source or maybe from a guitar into either an amp or a line in on a board. Also, wouldn't lower gain translate into lower noise/distortion? I also need to be able to make up the gain reduction at that 12AU7. Although changing the position of the cap would not be a lot of effort in a prototype.
There were some other thoughts on a couple of other forums about better loading the 12AU7 and in the process increasing the gain in the side chain, with a higher turns transformer. A 1:4 there I could in theory recycle backwards as an output transformer in another McTube or NYDave type preamp.
I plan to get some tube prototype boards off of Ebay and changing out the configuration shouldn't be too big a hassle. Using fixed resistors to start out in the attack/decay network on the side chain, there doesn't seem to be a whole lot of parts to this. Edcor xfrms are only about $4 more a piece than the the car isolations used in the PRR, and they would come with a center tap. The Edcors are only $10 or so. If I use 1:1's at the input and the makeup gain interstage, I can save them for the D-AOC (which is a much more ambitious project) if this doesn't work out. The tubes are pretty cheap. PSU isn't a problem if I use AC on the heaters to start with.
Old 12th August 2014, 03:26 PM   #24
vinyvamos is offline vinyvamos  Ireland
Very interesting thread Blue Jinn! :-) Have you made any progress/discoveries since your last post?
I too have been experimenting recently with a pentode and trying to control the gain using the Suppressor grid. I started off building a tube pre-amp within an existing chassis which has EF50 pentodes and a pair of EA50 diode tubes (Circa 1940s!). It started out as an overdrive/clipper unit but am now trying to control the gain of the EF50 using negative DC from a charge-pump circuit fed from a 12AT7. All rough experimentation really, and good fun . I am however quite sceptical of the linearity of gain control via g3, and am sceptical of distortion figures, although if my unit is still an overdrive with the bonus of compression a little distortion aint gonna hurt :-)...
Here is an interesting investigation/write-up on g3 gain control of the EF50 pentode. It looks quite linear based on the 2V steps in Joe's scope captures:
http://www.radiomuseum.org/forum/ef5...or_action.html
Old 12th August 2014, 04:33 PM   #25
Varying g3 voltage mainly collapses/expands the plate curves on the knee end or low plate voltage side. So for a signal introduced on g1, it will see compression/expansion control toward the knee end, but little effect toward the high plate V end. Causing considerable 2nd harmonic (and higher) distortion in SE mode.
The EF50 curves shown on Joe's site with g3 stepped, look evenly spaced but they are showing the effect of g3 signal for g1 = 0V only, not the linearity of g1 signal gain. What is needed is a set of the usual plate characteristics, each with stepped g1, and a new graph for each g3 voltage. Then the non-linearity would be apparent as just the left side collapses versus g3.
But you could put your signal on g3, and then use g1 as the gain control, giving a non-linear gain control function. ( like a log pot say)
There is a set of graphs shown there for g2 voltage changes between graphs (g1 stepped on each) of the EF50, and that set does show nice linearity (well, actually 3/2 power). So g2 control would make for a reasonable gain control of g1 signal.
The 6LE8 tube was designed specifically for differential g3 signal insertion, and has some datasheet graphs quite similar to the EF50 ( still not linear gain control by g3, but g1 can be used as the semi-linear gain control of g3 signal):
http://frank.pocnet.net/sheets/135/6/6LE8.pdf
For real linear gain control, the Beam Deflection Tubes (BDT) (or sheet-beam tubes) are the go to device. 6JH8, 6ME8
http://frank.pocnet.net/sheets/093/6/6JH8.pdf
http://frank.pocnet.net/sheets/049/6/6ME8.pdf
Old 12th August 2014, 04:37 PM   #26
EF50 suppressor action
Right now it's still on the drawing board. I also need to learn a bit more about pentodes. I'm not sure, but to my limited knowlede don't see why not, you can tie the screen to plate, but keep the suppressor separate. This sorta does that, but the GDIY folks thought the 6BA6 arrangement was odd:
The folks at GroupDIY gave it a real quick pass, didn't see any problem using the suppressor; one poster at HomerRecording.com thought the side chain was a little weak.
It was designed to work with ham radio, which perhaps wasn't intended to have a lot of gain reduction. Some additional thoughts:
Use a 12DW7 instead of a 12AU7;
Use a step down after the pentode to the "12AU7" section to keep the overall gain lower;
Use the "12AX7" and a step up to drive the 6AL5 harder
Old 12th August 2014, 05:04 PM   #27
@smokin-amp
Our posts crossed, thank you as well. More to think about. I've read other threads about using g3 as in input rather than g1.
using a pentode either way seems (and correct me if I'm wrong) to have the advantage of not introducing dc into the signal path, as you would putting the cv on the grid of a triode?
Old 12th August 2014, 06:00 PM   #28
Another quick thoughts: using a fixed screen supply?
Wouldn't that help somewhat with distortion?
Old 12th August 2014, 11:16 PM   #29
Took a quick look at the EF50 pages. It looks like an EF80/6BX6 would be equiv, with a more standard base. Or a 6EJ7 close enough. Both are US$5.00 at tubedepot.
Old 16th August 2014, 12:21 AM   #30
smoking-amp: Thanks for your detailed reply :-). I'm learning quick with all this experimenting. I might try signal on G3 then and alter G1 voltage for gain control. Will see then how non-linear it is. If I don't get usable results I'll just leave out the comp/limiting option and just leave it as a pre-amp/overdrive unit :-).
Bluejinn: The whole reason I'm using the EF50's with their strange bases is cos it's all in the chassis already :-). Otherwise I would go with something a lot more common and less archaic...
Seeing as your circuit was only designed for HAM radio use I really don't think it will be "hifi" and without distortion (same with mine probably!), but there's no harm in trying it! :-)
Pentode pre/compressor (warning nube attempt at circuit drafting) --suppressor gridHide this!Advertise here!
My attempt: 5 element Pentode Spice model aletheian Tubes / Valves 8 30th September 2013 01:19 AM
grid stopper and grid choke on pentode input YouAgain Tubes / Valves 3 12th February 2012 09:32 PM
good circuit to use with Grounded Grid Pre g(f(e)) Tubes / Valves 4 14th January 2011 09:03 AM
Beam pentodes and suppressor-grid pentodes of same type jon_010101 Tubes / Valves 3 2nd May 2009 11:18 PM
Pentode grid question... Brouilly Tubes / Valves 10 28th March 2009 07:02 PM
