Instruments and Amps Everything that makes music, Especially including instrument amps.
Old Intercom guitar amp project
Old 22nd February 2014, 08:14 AM   #21
jazbo8 is offline jazbo8
jazbo8's Avatar
I see, then I recommed that you get rid of the 10M grid leak, so the 12AT6 is self-biased, you can set the gain and voltage swing using the RC coupling chart below. Disconnect the plate supplies for the 12AT6 and 12AU7 from the 35W4's screen grid, by tapping off the B+ supply via voltage dropping resistors, and adding some bypass capacitors, so somewhere around 90-100V appears on the plates. The coupling capacitor should be connected between the plate of 12AU7 and the gain pot.
Old 22nd February 2014, 12:26 PM   #22
jazbo8's Avatar
Or just follow this schematic, the values for the 12AU7 may need to be adjusted from the ones used for the first 12AT6 below:
Old 22nd February 2014, 02:56 PM   #23
kuroguy is offline kuroguy  Germany
kuroguy's Avatar
Anybody understand the choice of 68k resistors when there are dual inputs?
"The magnet wire used to come from Radio Shack. In keeping with their policy of figuring out what the best products are and discontinuing them they no longer have it." - Max Robinson
Old 23rd February 2014, 06:16 PM   #24
LATUBEGEEK is offline LATUBEGEEK  United States
LATUBEGEEK's Avatar
Jazbo- thanks for the amplifier chart. Is this for a 12AT6? Not on the Tung-Sol data sheet I have, but found a similar one for a 6C4-another low-mu triode. Will help a lot! And I think the dual 68K inputs was just a popular choice for dual-input amps, but is just asking to be modified, to easily provide a different amp response (gain, briteness, etc).
Old 23rd February 2014, 06:32 PM   #25
jazbo8's Avatar
You are welcome, the r.c.c chart came from RCA and it's quite useful. The 68k's on the jacks provide hi and lo inputs, but can of course be modified to suit your own needs.
Old 23rd February 2014, 09:48 PM   #26
jjman is offline jjman  United States
Originally Posted by LATUBEGEEK View Post
"Have you measured the gain of each preamp stage? (ac volts out / ac volts in)"
jjman - I have just started doing just that, but using my scope, with a "guitar-level" 150mVp-p 1KHz from my SigGen. I just can't get used to preamp tubes working with only 16 VDC on their plates!! You notice I did add a 12AU7 to get more gain (and clipping to then control), so was able to eliminate the 300R heater dropper. Tube filaments are real close to desired. I did move the preamp (12AU7 & 12AT6) tubes B+ from pin 6 to 7 (on 50C5) to raise B+. Bad move.... Didn't move any voltages more than +/- 5VDC, but the amp was way squawky over 5 on vol pot. Reversed the change, and am back to (with 150mVp-p signal) 4.6Vp-p out of 12AU7, 32Vp-p from 12AT6, and 215Vp-p from the 50C5 (is this way too high, for 125VDC on 50C5's plate?).....Need to read up on AC signal voltage swings, gain and plate voltage.....and check my scope cal.
Looks like gain is ~31 in stage 1 and ~7 in stage two with a total preamp of 213. That’s double the ~100 in my single stage 12au6. So you have likely increased gain despite the very low plate voltages currently present. If noise is not a problem it sounds like it worked out. 215Vp-p sounds ok for the 50c5 but I would look at the output voltage on a dummy load instead of the plate. Safer and reveals the output wattage with some math. With guitars putting out more than 150mv p-p, I bet you’ll see clipping on the output with closer to 500p-p input.
I love trem but I wonder if your power supply has more slack to give.
Old 23rd February 2014, 10:26 PM   #27
LATUBEGEEK's Avatar
JJ- Thanks for confirming my signal/gain numbers look OK. I use a spkr/dummy switch box so I can crank this little guy (or a big guy) and not scare the dogs when using a SigGen.... Will check it there as well. And I see the Hi/Lo input strategy, with the top input it parallels the lower 68K with the 1M. That way lowers the grid leak R, attenuating the input signal (?). I will be modeling my tremelo on a Gregory amp (see pic), which uses the came tube complement (except for a lower-mu 12AU6 instead of the 12AT6 in my amp). Having added a twin triode 12AU7 I have a triode to spare. I think my only limitation on B+ is the iso xfmr (2.5A).... Can always add another 133V B+ feed with another filter/decoupling electrolytic...? The 35W4 is rated 660mA plate.
Old 23rd February 2014, 10:50 PM   #28
kuroguy's Avatar
Correct me if i'm wrong but 68k parallelled with 1 meg is only 63k, way too low an input impedance for a guitar to be plugged into the top input with the bottom input connected to ground. The way i see it, you plug into the bottom input if there's only 1 guitar and if there's two of you, you also plug into the top input. The 68k resistors just sum the two guitar inputs and they still see an input impedance of 1.068 meg.
Edit: a single guitar plugged into the top input would see an input impedance of 68k + 68k || 1 meg which is 131k
Old 24th February 2014, 02:31 AM   #29
gingertube is offline gingertube  Australia
Yes,
The top input is the low sensitivity input, guitar signal is divided by 2 by the 2 off 68K plus (as you say) the output from the guitar may be lower due to the loading effect of that 68K. This may well be dependent upon the guitars volume control setting which will affect the source impedance.
Ian.
The bottom input is the High Sensitivity setting where you have the "traditional" 68K grid stop and 1M grid leak.
Old 24th February 2014, 06:29 PM   #30
kuroguy's Avatar
Edit: never mind.
Old Intercom guitar amp projectHide this!Advertise here!
MASCO INTERCOM - GUITAR AMP PROJECT? LATUBEGEEK Instruments and Amps 5 15th January 2014 08:40 PM
Our Guitar Amp Project PB2 Instruments and Amps 38 7th May 2011 12:44 AM
Yet another Guitar amp project akis Instruments and Amps 24 28th September 2009 11:38 PM
Guitar Amp Project amperex Instruments and Amps 4 10th February 2006 07:56 PM
Copyright ©1999-2017 diyAudio
