Instruments and Amps Everything that makes music, Especially including instrument amps.
Balanced/unbalanced line receiver
Old 25th February 2014, 07:32 PM   #41
Bigtim1966 is offline Bigtim1966  United Kingdom
Hi Andrew, the resistors in the diagram (2M?) do go to signal ground. Which in itself raises a question. At the moment (based on other research) my signal grounds are connected to my chassis and supply grounds. I do intend to fit a ground lift switch which would isolate the signal ground from the chassis and supply grounds, but have not tested this yet.
In term of the resistors being in parallel with something. Are they not in parallel with the input opamp's Rin? I assumed this to be very high so concluded that the source would effectively see the 2M?
I understand that the guitar is not a balanced signal, my original spec was for a multi purpose input tat could accept an unbalanced guitar OR a balanced input (accepting that because it needs to be Hi-Z there might be a noise penalty) does that make sense do you think?
Old 25th February 2014, 07:51 PM   #42
diy didi is offline diy didi  South Africa
Rod Elliot ESP site is your answer.
Old 26th February 2014, 09:07 AM   #43
richie00boy is offline richie00boy  United Kingdom
Did it Himself
richie00boy's Avatar
The INA217 does not have internal resistors on the front end op-amp, the datasheet lists input impedance as 60 meg.
Carry on
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, modules and more.
Balanced/unbalanced line receiverHide this!Advertise here!
line level unbalanced to balanced converter steevo Analog Line Level 17 16th February 2014 04:09 PM
Balanced to Unbalanced Line Conversion Loren42 Tubes / Valves 33 4th January 2011 06:31 PM
Unbalanced to Balanced Line Level XFMR wrenchone Solid State 8 22nd October 2005 09:06 PM
Balanced line stage, quistion's + unbalanced lykkedk Pass Labs 4 20th December 2002 12:58 AM
Zen Balanced Line Stage Balanced vs Unbalanced macka Pass Labs 28 11th December 2002 07:18 AM
Copyright ©1999-2017 diyAudio
