Instruments and Amps Everything that makes music, Especially including instrument amps.
Diy combo guitar amp build log
Old 23rd February 2014, 07:42 PM   #31
kuroguy is offline kuroguy  Germany
kuroguy's Avatar
Transformers arrive later this week so I started wiring this amp. Here's the power supply caps and dropping resistors and a picture of the power,standby, and overdrive switch and LEDs. I use spare switch contacts as a terminal point for the LEDs. Power comes in the bottom and out to the LED from the middle. The LED lands on the top and then the return is from the top terminal. This way I don't need to add a terminal strip at the front panel and the wiring remains nice and neat. The LED is on when the switch is in the up position.
"The magnet wire used to come from Radio Shack. In keeping with their policy of figuring out what the best products are and discontinuing them they no longer have it." - Max Robinson
Old 25th February 2014, 01:37 AM   #32
kuroguy's Avatar
Worked on the LED wiring. A few zip ties will clean it up nicely. Also got the filament wiring done. The terminal strips for the LEDs, filament/pilot lights, fuse block are all on the left side of the amp. This is the "dirty" side and is furthestbfrom the audio amplification/signal.
Old 26th February 2014, 01:47 AM   #33
kuroguy's Avatar
Managed to get it about half way wired in about one and a half hours tonight. Will get the rest wired later this week. Also heard from Edcor today. They're running a little behind and should ship the iron next week. Still, 7 weeks lead time for the significant savings Edcor offers isa great deal any way you look at it.
Old 26th February 2014, 10:23 AM   #34
famousmockingbird is offline famousmockingbird  United States
looking good man. Make sure you double check Edcor's transformers before installing. They had taps that were the wrong colours according to the wire diagram (and common logic). It has happened to more people than just me. Other than that they are a good bargain for American iron.
Old 27th February 2014, 01:37 AM   #35
kuroguy's Avatar
Aside from mounting and wiring the transformers, this amp is done. I expext the transformers to arrive next thursday or friday and I can hardly wait. The first pic shows the overall wiring. The second pic shows the power supply. All those white wires are the various grounds connected to the star ground. hopefully, this amp will be silent until i command it to be crazy loud and distorted.
Old 27th February 2014, 03:52 AM   #36
gingertube is offline gingertube  Australia
Originally Posted by kuroguy View Post
I'm not so sure about the logo. I think i'll leave it off for now.
Nah! Put it on - I've been putting DUD25 and DUD15 on the little amps I've been designing and building.
DUD being a bit of tongue in cheek for "Down Under Design".
The guys I built the amps for love it but various others have given me a bit of "stick" about it saying I should take the amp building more seriously and that name does not present me as a serious professional.
Ian
Old 7th March 2014, 04:15 PM   #37
kuroguy's Avatar
transformers finally arrived. I estimate I'll have this amp done and buttoned up about 10 minutes after I get home from work tonight.
Old 8th March 2014, 07:14 PM   #38
kuroguy's Avatar
It's alive. 6av6 seems a bit microphonic and this amp squeals from the microphonic feedback with gain and overdrive all the way up when the volume is aboveabout 70%. Not sure what to do about that yet. Suggestions?
Diy combo guitar amp build logHide this!Advertise here!
Entirely DIY Guitar Amp Build Log kuroguy Instruments and Amps 40 21st March 2014 11:50 PM
2-Way OB Betsy-K / Alpha 15a with MiniDSP Active Cross Build-log and Measure-log danvprod Multi-Way 16 1st December 2013 09:03 PM
guitar amp enclosure/combo cabinet Aidan135711 Multi-Way 9 6th May 2010 07:43 AM
Custom Guitar Build Log LightwaveDude Instruments and Amps 40 31st May 2008 07:12 AM
