Instruments and Amps Everything that makes music, Especially including instrument amps.
Guitar preamp x stereo boombox
Old 2nd December 2013, 04:31 PM   #1
ATAUDIO is offline ATAUDIO  Austria
Default Guitar preamp x stereo boombox
Soo,
my artist friends now ask me to hook an electric guitar (a bass, really) to the boombox...
I havent found much suitable circuits, so I have made a tentative on my own.
It should work with any electric guitar to any home stereo or boombox (BTW, like http://www.diyaudio.com/forums/multi...ml#post3515004) line input.
Just do not abuse of your home stereo with your rock guitar! It won't last long
Supply is the usual 9V battery, should last about one day of operation.
Gain is 50, if somebody wants more, just change R6 to a bigger value.
I have use quad op-amps, since I have some good ones at home, so I have used one stage just for the voltage splitter. Of course a dual op-am (i.e. TL072) would do, just use two 1k resistors for a rough voltage spitter.
Any comment or suggestion is welcome...
@Audio
Old 3rd December 2013, 02:16 AM   #2
JMFahey is offline JMFahey  Argentina
JMFahey's Avatar
Nice design
Old 3rd December 2013, 08:01 AM   #3
Nigel Goodwin is offline Nigel Goodwin  England
Originally Posted by JMFahey View Post
Nice design
Seems a shame to waste an opamp though
Might be a nice idea to use it to add an extra balanced XLR output as well?
Nigel Goodwin
Old 3rd December 2013, 11:48 PM   #4
bparnell57 is offline bparnell57  United States
Line 6 Pod or just dont use an amp intended for music, it will sound pretty horrible, just buy a cheapo little used crate amp or something and torture that instead... hehe
Old 4th December 2013, 07:30 PM   #5
Thanks to all for the kind answers.
Some small improvements.
I added a poor man limiter (or soft clipping) using blue LEDs. They should start to act around 3Vpp , that is almost the value that saturates my boombox.
We'll see if it works.
There would be many nice things that could be done with the remaining op-amp, but that would inevitably complicate the circuit (that is already too much in my opinion) so I decided to do nothing.
BTW I am not too concerned for my boombox. If you have a look on the thread/ pictures you'll see that is done exactly for rough use. It survived already a dance summer camp....outdoors in the Alps ....and then this is DIY audio.....
@Audio
Old 7th December 2013, 04:26 PM   #6
Prototype done!: )
And tested with generator and scope:
The input is correctly amplified about 50x starting from about 15 hz to well after 10K, no instability or problems shown.
Clipping with the diodes happens at about 5.5 Vpp, when the diodes are fully bright.
Also I have done a test connecting it to my subwoofer amplifier, and using a small speaker driver as input ( I do not have an actual guitar by myself).
The thinghy is unbeliavely stable, and the noise floor is fair even with the cheap LF347 of the test setup... Consider the usual test setup, no shield/box, cables everywhere.
Even with a 100K series to the input speaker-microphone, it works very fine as a voice amplifier, just the hiss raises, of course.
So, it is time to close it in a nice box and give it to the rockers!
@Audio
Guitar preamp x stereo boomboxHide this!Advertise here!
Building a Small Stereo Boombox. Does this wiring layout look OK? LBKosmo Class D 19 20th June 2013 09:21 PM
Need 'stereo expander' circuitry for boombox 7V PC Based 8 1st April 2013 11:08 PM
Car stereo boombox Adamfbb Construction Tips 2 24th May 2012 03:09 PM
8" stereo ceiling speaker/MP3 boombox nordhaven Multi-Way 3 22nd January 2008 09:18 PM
what the hell is so stereo about a guitar?! electro samurai Instruments and Amps 7 14th July 2004 01:09 PM
