There shouldn't be a problem if they have source resistors as that will share the current better. If it doesn't have them or they are very low values then matching would be a good idea.
But, if they are bought from same batch they should be close anyway.
If the amp is blowing up then there could be loads of reasons why.
Okay I replaced a ton of stuff on that blown channel
Q202-205 MJE340 MJE350
D206-209 (1N3070)
Q206-209 (MPSA06 and MPSA56)
D210-213 (1N3070 and 1N914)
All the 47 ohm gate resistors
All the 470mOhm source resistors
The 1.5k flameproof resistors
And of course the output Mosfets.
I turned the bias all the way down and turned it on with a light bulb limiter.
No Smoke or funny smells which is good but I am getting 1vdc for offset on the channel that was blown before. I have no load on it and no signal, and like I said bias pots are set to maximum resistance for each channel.
Any ideas?
D206-209 (1N3070)
Any ideas?
I think I have to take it off the dim bulb tester..............the Vgs is only 1.8v..........................
B+/B- is 60vdc should be 82vdc
all voltages are low
Still don't know why I am seeing a 1v DC offset on the damaged channel. Which makes me not want to take it off the current limiter.
Can the amp be run without D214-217? They are 10v 1 watt zeners and they are all shorted. Are they for signal clamping? I will install them I just want to pull them out and run the amp with no signal to see if I can bias it up and I don't need anything else to add to the order. Unless anyone near Portsmouth NH has some 1N4740A zeners laying around they want to sell me
