Instruments and Amps Everything that makes music, Especially including instrument amps.
Scratchy rattling resonance
Old 17th September 2013, 09:07 AM   #11
JingleJoe is offline JingleJoe
I had to sign up just to reply to this thread because I was dealing with this exact problem in a filter I built recently!
The resonance in my filter is acheived by adding feedback at a certain point in the signal path which increases Q factor and morphs the filter type into chebyshev, if your circuit is in any regard similar to this we may have had the exact same problem!
Although I can't tell for sure without a schematic.
The problem was that I was overdriving the amplifier portion of the filter. The waveform was hitting the rails and this caused no resonance to happen. Additionally when the input waveform peak to peak voltage exceeded the voltage fed back, less resonance happened. This was due to feedback limitation acheived with diodes.
Basically it's all down to overdriving your resonant parts.
When things were on the edge of resonance attenuation due to overdriving, it got really rattly and scratchy just as you described! I've adapted my filter to encorporate this- it's a feature now, not a bug
Things also got pretty raw when I had some offset voltage fluctuations in a previous design. Sometimes a signal present would cause certain parts of the circuit to become biased up, resulting in the waveform hitting the rails again and loosing resonance and getting all rattly. This happens especially when the input waveform has unequal high and low portions.
To overcome it, I simply attenuated the input signal a lot and amplified the output. This was fine for my specification and didn't even use that many more components but I can see how it would be undesireable for many applications.
Old 17th September 2013, 09:12 AM   #12
Last edited by JingleJoe; 17th September 2013 at 09:20 AM. Reason: double post! sorry :s
Scratchy rattling resonanceHide this!Advertise here!
Why is my woofer rattling? psyphre Multi-Way 20 8th August 2013 02:49 AM
Crate V212B rattling DeadSpeaker Instruments and Amps 3 13th November 2008 07:12 PM
Rattling Tube dsavitsk Tubes / Valves 4 18th October 2005 06:06 PM
Rattling and Dynamat NaftaliG Car Audio 4 14th August 2004 04:34 PM
my sub is rattling! bobbydigital Subwoofers 2 8th January 2004 06:58 PM
