Instruments and Amps Everything that makes music, Especially including instrument amps.
Sweet distortion
Sweet distortion
Old 12th September 2013, 02:32 AM   #11
shanx is offline shanx  Canada
I totally did not expect to see that this type of waveform was giving me this Ohh Sooo Sweet Sound!!!
There is probably loads of theory to discuss about that scope-traced waveform, but suffice to say that is the signature of a well done guitar preamp which pretty much nails that overdriven sound.
Old 14th September 2013, 05:53 AM   #12
cyclecamper is offline cyclecamper  United States
Originally Posted by Jsixis View Post
If I had known then what I know now I would have bought a Peavey Classic 30 head instead of the classic 50.
The Peavey classic 30 and classic 50 both use 4 EL84 outputs. You won't get the same exact tone or the same power supply sag compression, but you can install a half-power switch to disconnect two cathodes. A power soak resistor switch helps too. If you search there's also the Blue Guitar mods for the Classic 50.
Old 15th September 2013, 08:46 PM   #13
Jsixis is offline Jsixis  United States
wow, I thought the 30 was just 2 el84's, learn something every day.
I have a friend who will just pull 2 tubes out of his 50
I'm not that brave.
Old 15th September 2013, 09:11 PM   #14
Nigel Goodwin is offline Nigel Goodwin  England
Wouldn't have thought so?, 2xEL84 gives about 12W, and 4 gives 24W or so. Bear in mind these are 'proper' RMS watts at reasonably low distortion figures, not guitar massively distorted ones.
Likewise EL34, 2 are 25W, 4 are 50W.
Nigel Goodwin
Old 16th September 2013, 04:39 PM   #15
geraldfryjr is offline geraldfryjr  United States
If I remember correctly the original Classic had four 6L6's in it.
Maybe it was modded for them I don't remember as it was 32 years ago.
I know this because it was a friends amp and one of the tubes exploded and took out the power fuse.
I just happened to have a few of them and 20amp ceramic fuse with me at the time and got him back running again instantly.
We rocked it for the rest of the night with no other issues.
Ever since that night I have always wanted to get one but they had quit making them!!
The next time they reissued the classic it had a solid state preamp so I didn't get one of those and I ended up with the Peavey Renown 400.
The original classic was all tube.
jer
Old 17th September 2013, 12:38 AM   #16
I'm talking about the newer Classics mine is a classic 50 with 4 el84's which I always thought was typical peavey BS because they over rate all of their amps even their solid state amps.
Old 17th September 2013, 05:53 AM   #17
The "tweed" classic 50 really puts out 50 with the same output tubes as the "tweed" 30. The "tweed" classic 100 is the same as the 50 but has two of the output board and cage stacked and bigger transformers. The EL84's just do sound different than just about anything else IMHO, chimey clean like a small VOX and break up early. But a VOX 50 went to El34s; I don't know of anything else but the Peavey that used those crummy little EL84 table-radio tubes to such extremes.
Sweet distortionHide this!Advertise here!
Sweet Peach EL34b Amp - Distortion? wirralguy Tubes / Valves 53 18th February 2012 11:53 AM
The Sweet Spot Nelson Pass Pass Labs 54 12th November 2009 01:53 PM
FS: Sweet!! HP339A Distortion Measurement Set cowboy99 Swap Meet 7 24th October 2009 10:37 AM
Sweet tweeter Guss Multi-Way 12 6th July 2003 01:28 PM
