Instruments and Amps Everything that makes music, Especially including instrument amps.
lafayette pa 622 -> Guitar amp conversion
Old 1st August 2013, 12:18 AM   #1
dsulliv5 is offline dsulliv5
Default lafayette pa 622 -> Guitar amp conversion
Hi good folks of diyAudio - I have been lurking about for a while enjoying the goings on about the joys of working on simple amplifier circuits. I scored a 1969 Lafayette PA amp in working condition the other day and want to make it into a decent guitar amp. It already has a 1/4" input jack and handles a guitar signal pretty well. It just needs some improvements to become a respectable guitar amp.
The first thing I want to do is remove the two aux-ins and the common volume control for the two aux inputs. It appears to generate a lot of noise. This vol control is in addition to the 'mic' vol control so it is redundant for my purposes. In the photo the 'mic' volume is on the right and the shared volume (CCW from 12:00 turns aux 1 up, CW from 12:00 turns aux 2 up) is on the left. Can I disconnect the cap and resistor from the top of the shared volume pot and connect it to the lead that comes out of the bottom of the shared pot, thereby bypassing the aux input vol?
there is also a single tone control which I would bypass if I had any idea what that would do to the circuit as well. It has a .02 cap on it and I believe it is a 1 Meg pot. So perhaps I should improve it before removing it completely. Any ideas about how to improve the tone?
The amp already has lots of gain - probably from the 6AV6, but I don't even know what that is doing although it looks like it is being used as the PI.
Anyway - any guidance would be appreciated.
Old 1st August 2013, 02:05 PM   #2
DF96 is offline DF96  England
Instruments and Amps forum?
lafayette pa 622 -> Guitar amp conversionHide this!Advertise here!
Whitley PA Guitar Conversion JoelKnauber Instruments and Amps 26 17th August 2012 06:03 PM
McGohan M506 PA Guitar conversion mods. adddakid Instruments and Amps 2 25th April 2010 01:32 PM
Tube PA to Guitar Amp Conversion Help valadezpm Instruments and Amps 3 6th February 2009 10:45 AM
Resources for PA - Guitar amp conversion pjanda1 Instruments and Amps 1 21st August 2008 07:23 PM
Bogen PA to Guitar Amp, few questions Turbo7MN Instruments and Amps 100 5th April 2006 01:41 AM
