Instruments and Amps Everything that makes music, Especially including instrument amps.
do I need a cathode follower?
Old 18th July 2013, 09:22 AM   #11
jazbo8 is offline jazbo8
jazbo8's Avatar
You need the 0.1u screen bypass capacitor, otherwise your gain will be low, so leave that alone, now some suggestions:
1) Get rid of the pentode/triode switch and run in pentode mode only if you want the Vox chime.
2) Change the 680k to 200k, and connect it to the 20k pot, or better yet, replace both with a proper 250k log pot. Too much series resistance is killing the highs, you can add a bright cap across the 680k as suggested by djgibson51, if you do not have any other lower value resistors to replace it.
Jaz
Old 18th July 2013, 09:31 AM   #12
djgibson51 is offline djgibson51  New Zealand
Check out "The Valve Wizard - Small Signal Pentodes".
C3 does the same job as C2 ie prevents -ve feed back.
You could reduce either to boost treble (actually reduce bass) in this circuit.
Sorry jazbo - cross post
Old 18th July 2013, 09:43 AM   #13
emosms is offline emosms  Bulgaria
Thx all!
I have set 680k to prevent high voltage on the output.
Not sure if 250k will give usable output voltage range out, have some such pots at disposal.
The sound card would clip badly, mby even get its input burned.
Another pros for cathode follower solution?
(eliminating high resistance before output, handling the full voltage amplitude, plus low output impedance)
Still I will try it the simple way first, with a bypass cap on the output resitor.
p.s. the sound card has 250/400k (lo/hi) input impedance, no idea about the capacitance.
Tried both with 0.5m and 3m cables for the guitar, I dont hear such a big difference.
Old 18th July 2013, 10:01 AM   #14
jazbo8's Avatar
Originally Posted by emosms View Post
Thx all!
There is no high voltage after the output coupling capacitor, it blocks all the DC from reaching the soundcard. If you are only playing guitar through this preamp, I doubt you can generate enough swing to damage the soundcard's input. But to be safe, you should always have Zener clippers to protect over-voltage to the card.
In this case, I don't think a CF will make a drastic difference, so probably not worth the trouble of adding another tube, but it is up to you.
do I need a cathode follower?Hide this!Advertise here!
Help? 6n23p cathode follower ericj Tubes / Valves 20 25th November 2013 03:01 PM
cathode follower vlljpior Tubes / Valves 6 22nd March 2005 08:50 PM
Question about direct coupling a anode follower into a cathode follower. G Tubes / Valves 45 29th July 2004 07:47 PM
cathode follower ackcheng Tubes / Valves 2 6th July 2004 04:12 PM
cathode follower olvrkrg Tubes / Valves 3 21st February 2004 10:49 PM
Copyright ©1999-2017 diyAudio
