Instruments and Amps Everything that makes music, Especially including instrument amps.
Guitar Tube Preamp
Guitar Tube Preamp
Old 11th July 2013, 02:39 AM   #1
fermaciel1771 is offline fermaciel1771  Brazil
Send a message via MSN to fermaciel1771
Default Guitar Tube Preamp
Hi to all!
I've planning to build this preamp shown in PDF attached. In theory the desingn is pretty cool, I'm think... The original ideia is using 2 double triodes Tungsram's ECC83 (ECC 83S by JJ, 12AX7 LPS by Sovtek). Both clean and Lead Mode share the first triode of one ECC83 and the Lead mode use Cathode Follower. The diodes are optionally can be switched to add a typical saturation of a semiconductor and the sound is little harder. I'm hope this preamp works fine. I'm want to know the opinion of the DIYers for the circuit desing and any suggestios are wellcome!
my best regards,
Fernando M.
Old 11th July 2013, 02:56 AM   #2
kevinkr's Avatar
Guitar Tube Preamp
All musical instrument threads belong in Instruments and Amps per the below:
Tubes / Valves All about our sweet vacuum tubes Threads about Musical Instrument Amps of all kinds should be in the Instruments & Amps forum
Moved...
"To argue with a person who has renounced the use of reason is like administering medicine to the dead." - Thomas Paine
Old 11th July 2013, 01:08 PM   #3
ingenieus is offline ingenieus  South Africa
Looks good.
The idea of adding semiconductor distortion to a tube input stage is very interesting! I have been playing around with adding tube distortion to semiconductor output stages and now I see that it is also done the other way round.
Old 11th July 2013, 07:52 PM   #4
Originally Posted by ingenieus View Post
Looks good.
The original idea to adding diodes for distortion is based on MesaBoogie's VTwin, but I'm design the circuit above to appreciate the sound of tubes, so the MesaBoogie's design uses TI TL072 Operational Amp.
[]'s
Fernando M.
Old 12th July 2013, 09:37 AM   #5
funk1980 is offline funk1980  Netherlands
funk1980's Avatar
Your tone controls, but more importantly, you output is going to react very different depending on the channel (lead/clean) you chose. One is taken from the anode and the other from the cathode (follower). The output impedance from these arrangements are totally different. You could consider adding an extra tube to act as a buffer for the clean channel and output.
Old 13th July 2013, 12:35 AM   #6
Thanks for sugestions, I'm not attepmted about differerences of impedances in clean/lead modes. So I'm add one more tube and using 2 cathode followers, 1 for clean and for the lead stay as shown above. I'll modify this design to looks better!
[]'s
Fernando M.
Old 15th July 2013, 08:07 PM   #7
Struth is offline Struth  Canada
Banned
Hi Guys
You'll find the plate-driven EQ is much more dynamic and the controls will seem to do something. Cathode-driven EQs tend to lack control. TUT6 explains this in detail.
Clipping the output of the first stage is similar to the Poor Man's Overdrive in TUT. There a single diode pair was used and the resulting distortion is mild at best. Using three diodes each way, as the bridge+diode presents, will produce even less distortion. Unless you want the clean channel to be significantly louder and/or noisier and/or to have more tube character than the lead channel and/or you want a very low output all-around, , then you are best advised to convert the CF into a real gain stage. Move the diodes to the output of the (now) third stage of the lead path and make them switchable. Add an interstage attenuator between the 2nd and 3rd stages to avoid grid rectification. Now you have effectively the Ultra-low-noise version of the LPSP from TUT.
Have fun
Kevin O'Connor
Guitar Tube PreampHide this!Advertise here!
Guitar Preamp Tube combination dart56 Instruments and Amps 4 8th February 2008 01:03 AM
Tube Preamp as a Guitar Effect fresno Instruments and Amps 4 28th March 2007 02:20 AM
Radio tube guitar preamp AmpKiller66 Instruments and Amps 2 7th March 2007 06:38 AM
Looking for tube guitar preamp high-fi Instruments and Amps 10 24th May 2006 02:27 PM
Guitar Tube Preamp Kaiowas Instruments and Amps 5 24th April 2004 10:21 PM
Copyright ©1999-2017 diyAudio
