Instruments and Amps Everything that makes music, Especially including instrument amps.
Critique my preamp design
Old 14th June 2013, 07:28 PM   #1
JFace is offline JFace  Canada
Default Critique my preamp design
Attached is my first design for a bass guitar tube preamp. The goals of this design are:
-Boost a passive bass signal (~0.01V) to line level
-Tone shaping via James tone stack
-Tone shaping via active mid cut/boost a la ampeg svt
-Lightly compress and distort the signal for a bit of coloration
-Drive a power amp input
-Drive a long balanced cable length to sound board
I'm very open to constructive criticism on my design and advice on how you might accomplish these goals.
Thanks in advance!
Old 14th June 2013, 09:10 PM   #2
funk1980 is offline funk1980  Netherlands
funk1980's Avatar
What is your B+ going to be?? Some design decisions depend on this.
The first 12AX7 will probably be biased around 1.5V. A lot of basses, even passives, put out peaks way above that. I measured peaks up 5V on one of my active basses. So you might consider a second padded input (-15dB for example), so you can leave the drive/distortion completely up to the second stage.
For reference, see pic below, just ignore the second stage and other and on:
One other thing is the master volume after the 4th 12AX7. The 1M volume put is in parallel with the 30k resistor. Why not use a 50k pot instead and reduce the noise produced by the 1M piece of carbon and reduce the part count.
It also seems you amplify the signal a substancial amount a couple of times and the reducing it again by means of a voltage divider. Signal to noise ratio will suffer severely.
Old 14th June 2013, 09:39 PM   #3
I'm planning on 300V.
Good idea, I like it.
This is the area I'm most unsure about. How do I benefit from the massive gain of tube amplifiers while still maintaining line level output? I didn't want to give the dc coupled cathode follower a tiny signal, assuming I would not benefit as much from it's inherent compression and non-linear characteristics. Should I decrease the beginning gain stage, or only have one voltage divider, or both? Or completely redesign
Old 14th June 2013, 09:56 PM   #4
JMFahey is offline JMFahey  Argentina
JMFahey's Avatar
To be frank :
1) it looks way too much like an Ampeg SVT preamp.
As in 95% alike.
2) it looks like you didn't want to straight copy an Ampeg SVT preamp, so, without *really* varying the design, you modified each stage, one by one, replacing it with either a home brewed stage or something copy and pasted from somewhere else.
Either way it does not "better" the original design but potentially worsens it, and adds errors.
As example:
a) the tone controls.
The treble boost and cut have been raised one octave relative to a classic Ampeg stack.
This will work properly in a Hi Fi preamp, where you have cymbals and such, reproduced with tweeters, but in a Bass amp with Bass speakers it will be perceived as "weak"
The Bass range has also been raised roughly 1 octave, it will be perceived as having too much midbass, maybe "muddy" or lacking depth.
The full adjustment range has also been reduced by some 12/15 dB, so it will be perceived as "doing little".
I suggest you download Duncan's "TSC" , the tone stack checker, and trace it both with original Ampeg values and with the new ones, you can save and compare memories.
Believe me that Ampeg values have been the benchmark for over 60 years for some reason.
3) the way the midrange control was implemented, it works almost as the original when attenuating, but on boost, instead of the original *very* noticeable 20dB, it will have very anemic 3 or 4 dB, almost nothing.
4) you copied wrong the balanced line driver, the top unity gain follower is fine, but the bottom stage is open loop (ay, gain 1000000 at low frequencies) and its output will probably be slammed against a power rail juust because of uncompensated offset.
Personally I would straight copy an SVT preamp (in fact I do exactly that on customer demand) , play with it, get to know it well, and then, based on that experience, start tweaking it to better some aspect where I think it can be done.
As of the line driver, it's almost there, but in the bottom Op Amp, connect the 10K resistor from the output to the -in , and ground the +in.
And for safety, add a 10K to 22K resistor from Master pot wiper to to +in, and from there reverse biased diodes to +15 and -15 rails, because with that tube preamp, if you set the master to 10 and play loud, you *may* surpass 15 V peak either way and damage the TL072 input.
EDIT: when posting I read:
Don't worry about that.
You will have no compression and very little (if any) non linearity in that stage, unless you hit it with a sledgehammer (signal wise) and at the same tine load it with a too low impedance signal .... and nothing of that will happen.
Old 14th June 2013, 11:12 PM   #5
The only thing that I took from ampeg was the mid control method...I haven't seen any other maker do an active one like this. Everything else was following the book Designing Tube Preamps for Guitar and Bass by Merlin Blencowe. When I compare this to the 1972 svt pre, I don't see a ton of similarities. Some things are bound to look similar, as they are in almost all guitar/bass applications, but I wasn't trying to rip off the ampeg svt.
Good catch on the op amp section...I was kinda rushing at that point.
I'll have to take another look at the James tone stack. I did use the Duncan Tone Stack calculator and it seemed to have a good looking response to me.
I don't quite follow why my implementation of the mid control doesn't match the same gain capabilities as the svt. Can you explain that?
Thanks for your feedback, I am excited to wire this up.
Old 15th June 2013, 01:38 AM   #6
JMFahey's Avatar
1) please take what I answer with no offense (I'm sure you didn't, but it's better keeping things as transparent as possible)
2) you also took the block diagram, to call it some way, but replacing what's inside each block with a functional equivalent, that's what I mentioned.
The end result is still very recognizable and amounts to about the same.
Didn't know where you had pulled stuff from, and if it's Merlin's book, fine, it's a good resource.
Never read his book but saw his contributions in various Forums and he's clearly a serious guy
Well, I already told you what I see, but to clear doubts, "an Ampeg SVT preamp" architecture (which is recognizably very different to, say, a Fender or a Marshall, to name 2 "big ones") can be described , in a *very* simplified form, as follows:
"a roughly 50X gain stage > passive fixed EQ (lossy, around -10X) > 1M volume pot > gain stage to recover Passive EQ losses (around 10X) > James tone control (lossy, around -10X) > active (3 tubes) midrange gain block. Gain=8X (56K/8K) > cathode follower > output."
*IF* you pull the lossy fixed EQ (Ultra Hi/Lo) *and* the gain stage which was added only to compensate that loss, the preamp stays exactly the same as before, simply "you didn't push any of those buttons".
"a roughly 50X gain stage > 1M volume pot > (you will need here some kind of buffer to replace the 10X gain stage) James tone control (lossy, around -10X) > active (3 tubes) midrange gain block. Gain=8X (56K/8K) > cathode follower > output."
The preamp won't sound, say, Fenderish or Marshallish but still *very* Ampegish .... because that's what it is.
If you wish, in other moment I can split Fender and Marshall typical preamps in blocks so you see both are very different to this one (and between them).
Now I don't want to mud what we are talking about.
Now to yours:
"a roughly 50X gain stage > 1M volume pot > (unity gain buffer ) James tone control (lossy, around -10X) > active (1 tubes) midrange gain block. Gain=(let's calculate it when analyzing this midrange control)[/] > cathode follower > output.[/I]"
As you see, it's very much the same.
So much so that on purpose I copied and pasted the Ampeg description .... and it still fits yours
What do I mean by that?:
I look at circuits as functional blocks, "what they do" , which by the way is excellent for quick troubleshooting.
Don't care that much for "parts" alone, even less so about brands, and talks about cap or resistor colours, composition or vintage make me sick , I *do* care (very much) about how systems (which are a combination of parts in a certain way) behave, measure and sound.
So if a gain block was made with a tube which carries a certain name, and now is replaced by another with a different name but which works roughly the same, clips at about the same level, has about the same gain, etc., for me it's functionally the same.
Fine, always happens.
When I post some schematic, I also ask others to double check.
Sure it looked good.
In fact it's fine, but more useful in Hi Fi (or PA or Keyboard) amps like in a Bass one.
FWIW, Polytone amps use "Hi FI preamp" type tone controls , as I said way too much midbass and weak treble ... maybe that explains why those amps are loved by the Jazz cats and their archtop fat body guitars, using *fat* strings
Yes, of course.
Ampeg made a very high gain block using 3 tubes, then applied heavy feedback to lower that gain to only 8X, but they have a lot of gain in reserve if needed.
In tube amps, losing gain is *easy* (that explains passive tone and gain controls everywhere) but boosting gain is not, because to begin with there's very little, if any, "untapped " gain available.
To some (many?) this will sound like an insult, for me it's the highest compliment: that Ampeg gain stage is almost as good as an Op Amp
Its gain can be accurately predicted (notice I stated 8X while all others were "around something").
Gain is 1 + R35/(R29+R30)= 1 + 56K/8K=8X
Ampeg states that the midrange control has "+/-20dB range", at the resonant frequency, of course.
Let's see:
To get 20dB boost (10X gain) we need to parallel (R29+R30) (8K) with something 1/10 its value, say, around 800 ohms .
What do we have?= R34 (470 ohms) + the DC resistance of the coil.
Will those add up to roughly 800 ohms?
I bet they do .... or quite close *
Now to the attenuation.
The attenuator is made out of R37 (47K) and R36 (6K8) .
We need something in parallel with R36 with impedance, at resonance, around 1/10 that or around 680 ohms.
Well, we have R39= 620 ohms (surprise ) plus the DC resistance of the inductor, which I estimated before in around 100 to 200 ohms. Or not very far from that.
As you see, Ampeg design was *incredibly* accurate, clearly made by very good and experienced Engineers.
Not "something drawn on a napkin and tuned by throwing random parts at it"
Now you'll understand the main problem in yours: you have a single gain stage, run already *almost* full gain, there's *very* little extra.
So it will work properly (like in most classic tube circuits) attenuating, you put 470 ohms in parallel with 4K7, fine, similar to what Ampeg achieves.
But on boost, even if you skip the series resistor, you are putting the inductor DCR in parallel with the 1K5 cathode resistor of a 12AX7 .... you have at most 3 or 4 dB available to boost .... very far from the original 20dB.
So I took 1000 words to repeat what I had already said in 20 or 30, oh well
Hope it was somewhat useful
You're welcome
It will work, no doubt, but if measurements (or perceived sound) don't come up to what you expect, don't worry.
And please don't rebuild it using $300 capacitors made out of Platinum , Egyptian mummy papyrus and Moby Dick white whale oil, because that's not the point.
Magic is irrelevant, the point rests on hard work and knowing what you do.
Good luck
Old 15th June 2013, 01:50 AM   #7
Enzo is online now Enzo  United States
And just a thought. You have this tube preamp going, and then one lonesome TL072 driving a balanced out. That is going to require a whole extra split power supply just for the one chip. Maybe consider just biting the bullet and buying a nice transformer, which your tubes could easily drive.
Old 15th June 2013, 04:09 AM   #8
No offense taken at all...I put my schematic up for critique. I admit I'm a noob, and expected more of a beating than I actually took. I appreciate your comments.
I'll briefly describe my design methodology. Working backwards:
I wanted to end with a line level output
I wanted to buffer the overall sound at the end and control it with a master gain
I wanted the distortion/compression character after the eq, thus the DC coupled cathode follower
The eq section comes after the initial gain stage for maximum effect and minimum noise
To be honest...this is one of about 5 topologies that I drew on a napkin (sticky notes actually).
This is very much how I would like to operate. I'm more of an engineer than a cork sniffer.
I follow everything up to this point...I thought that I'm getting a pass band gain of about 30 at this part...and then a gain of ~50 for the resonant LC circuit when the mids knob is set to max (resistance of 0 ohms from the cathode). The mids knob shifts the circuit from an unbypassed grounded cathode to a bypassed grounded cathode with the LC circuit determining what frequencies get the extra boost from the bypassed arrangement. Curious to see if you follow my logic here or if I'm mistaken.
Old 15th June 2013, 04:13 AM   #9
Funny you mention that...I originally had in mind a Jensen 10k:600 output transformer, and in another thread it was mentioned I could go with op amps. Either way I'm giving up real estate for a transformer.
Old 15th June 2013, 04:43 AM   #10
Yeah, the op amp and parts need space, but so do the rectifiers and filter caps and regulators for it, and either a larger transformer (with the extra winding) or a second transformer.
Critique my preamp designHide this!Advertise here!
preamp help w/ critique impsick Solid State 1 16th October 2007 12:01 PM
Critique my first design bigwill Tubes / Valves 11 3rd June 2007 12:30 PM
Design critique MWP Digital Source 6 22nd August 2004 05:20 AM
Design critique MWP Chip Amps 6 20th August 2004 04:54 AM
Please critique this design.... Christof Multi-Way 22 10th January 2004 08:17 AM
