Instruments and Amps Everything that makes music, Especially including instrument amps.
voltage to sound
voltage to sound
Old 21st April 2013, 11:20 AM   #1
budscott is offline budscott
Default voltage to sound
I have a device that outputs 0 - 5v DC. What's the easiest way to turn that into sound? The most basic would do. Many thanks folks. Looks like a fun forum!
Old 21st April 2013, 06:52 PM   #2
Minion is offline Minion  Canada
What is the output ?? does it output audio , or DC Voltage or AC voltage and what type of device ??
It"s a very broad non-specific question you have there .....
Old 21st April 2013, 06:58 PM   #3
It's an EMG sensor. It outputs 0-5 volts and I'd like the output as changing pitches rather than just voltages.
Old 22nd April 2013, 12:29 AM   #4
indianajo is offline indianajo  United States
indianajo's Avatar
You can run the DC to a voltage to frequency converter. Then run the frequency to an powered speaker. V/F converters are in books of NE555 projects, or you can use half of a a NE567 Phase lock loop, or look on one of the circuits websites for a voltage to frequency converter.
Or you can drive a speaker with the dc and an instrumentation amp, but only elephants will hear the sound.
Dynakit ST70, ST120, PAS2,Hammond H182(2 ea),H112,A100,10-82TC,Peavey CS800S,1.3K, SP2-XT's, T-300 HF Proj's, Steinway console, Herald RA88a mixer, Wurlitzer 4500, 4300
Old 22nd April 2013, 05:11 AM   #5
Thanks. Sounds like the answer. I'll look into that right away.
Old 22nd April 2013, 05:47 AM   #6
Would this do?
Easy to make?
voltage to soundHide this!Advertise here!
Sound Technology 1700a Voltage Calibration Grid2 Equipment & Tools 0 22nd December 2010 10:20 PM
Sound card input voltage range? J.R.Freeman PC Based 6 17th March 2010 09:16 AM
What makes a voltage source sound good? Onvinyl Power Supplies 28 7th August 2008 07:29 PM
Plate voltage related to sound? jtrujillo Tubes / Valves 1 9th July 2006 06:53 PM
Increase voltage for better sound.... Mikka Solid State 1 18th May 2003 05:23 PM
Copyright ©1999-2017 diyAudio
