Instruments and Amps Everything that makes music, Especially including instrument amps.
Modified Alembic F2-B
Old 3rd May 2013, 04:40 PM   #21
Passinwind is offline Passinwind  United States
Passinwind's Avatar
Originally Posted by Stormrider View Post
Got some time off, and it was a nice spring day so decided it was time to get some real work done on this project out in the garage.
This is the first turret board I've done, so I made a DIY anvil and swage as per the tubedepot plans, with one exception. I had to use a 2" bolt for the anvil as most of my turrets were placed pretty close together. Also, not that the 1540-4 turrets require a 3/32" through hole for swage fitting. Use a #43 drill bit for press fitting.
It was a lot of fun to make, and I think it turned out pretty good.
Nice job, I need to give that a whirl sometime. I'm building a tube bass preamp myself at the moment (1-6SL7, 2-6SN7s), here are my first-ever attempts at doing printed circuit boards:
-- Charlie Escher
Old 3rd May 2013, 05:13 PM   #22
cyclecamper is offline cyclecamper  United States
It will still be a while before I even start ordering and collecting the small componets for the naked double-sided Trace Elliot V8 circuit boards. I'm pretty thrilled though that the preamp is just as exceptional as the power amp. The preamp has a switchable additional gain stage and a good controllable tube compressor.
It seems to me it's not much more trouble to build two, since most of the work is in finding the parts when I already have the circuit boards. So far I have two preamp boards and one poweramp board and one set of transformers.
Old 3rd May 2013, 05:42 PM   #23
Passinwind's Avatar
Those boards look like a great deal. Tube power amps are just not my thing really, but ...
-- Charlie Escher
Old 3rd May 2013, 05:48 PM   #24
Stormrider is offline Stormrider  United States
Stormrider's Avatar
Send a message via AIM to Stormrider Send a message via MSN to Stormrider
Hey Charlie, fellow talkbass guy here. Nice PCB's! Did you do the fabrication yourself, or have them made to your design?
The turret board was pretty easy to make. Hardest part was filing down the bolt to make the swage, but that was mostly due to my crappy files and slow drill press. Came out good though, the turrets locked into their holes nicely. The epoxy coated G10 is also pretty easy to work with. Cut smoothly with a jig saw. I did the layout in Draftsight which is a free 2D CAD program that resembles AutoCAD pretty closely.
AJ
Old 3rd May 2013, 06:18 PM   #25
Passinwind's Avatar
I used OSHpark for fab, who are now handling BatchPCB's order fulfillment as well. The only real downside is having a 3 board minimum, but everything else about using them is pretty painless -- not counting learning how to use KiCad or other board layout software of your choice.
Thanks for the Draftsight tip, that would've come in handy for all the custom mechanical bits I've been making.
I linked this thread on TB, by the way.
-- Charlie Escher
Old 3rd May 2013, 07:48 PM   #26
Stormrider's Avatar
Where at? I can't seem to find the thread. I was going to make a thread for this over there once I got it done and it was worth looking at.
AJ
Old 3rd May 2013, 07:53 PM   #27
Passinwind's Avatar
Might've just been in some PMs to a couple of F2B owners I know, now that I think of it. Please do post your own thread there when you feel like it though.
-- Charlie Escher
Old 3rd May 2013, 09:29 PM   #28
Stormrider's Avatar
Finished as much as I could of the board for this project. I was short the small caps for the treble control and the bright/deep switches. I think it came out pretty good. I wasn't happy with the layout around the two big caps in the tonestack, and I underestimated the size of the high current diodes for the ground loop breaker. Not bad for my first turret board.
I also attached a pic of my other project, which includes my first PCB design. That will get a thread here as soon it's done, as well. It's a stereo, buffered volume control featuring turn-on/off muting via shorting relay and an Alps Blue Velvet volume control.
By the way, sorry for the crap photos. I need better lighting and a real camera.
AJ
Old 3rd May 2013, 09:31 PM   #29
Stormrider's Avatar
My first PCB design...
AJ
Old 14th May 2013, 10:09 PM   #30
Stormrider's Avatar
It's official, the Allied 6K27VF really is a drop in for the old Stancor PS-8415. Everything down to the color code is the same. The Allied uses a modern plastic former, but fits in the same space the Stancor does.
AJ
Modified Alembic F2-BHide this!Advertise here!
Improving upon the Alembic preamp ClydeWilliam Instruments and Amps 5 29th January 2013 04:59 PM
Alembic F2-B phil mailloux Instruments and Amps 101 12th October 2011 02:07 PM
Alembic F2-B project gone cookoo Nordskov Instruments and Amps 3 17th June 2009 08:03 PM
Pre/PS ala Alembic croat47 Instruments and Amps 3 16th March 2006 01:50 PM
Alembic F-2B mbonus Instruments and Amps 3 3rd March 2006 04:55 PM
Copyright ©1999-2017 diyAudio
