Instruments and Amps Everything that makes music, Especially including instrument amps.
Modified Alembic F2-B
Old 22nd April 2013, 06:55 PM   #11
cyclecamper is offline cyclecamper  United States
If you feel a little more ambitious and want to try another slighty more complex classic tube bass preamp, I have an extra unpopulated high-quality double-sided printed circuit board for a Trace Elliot V8 preamp, which includes a switchable additional stage for overdrive, and an equisite controllable tube compressor. The extra stage and on-board compressor make it much nicer than their V-series preamp. The V8 was the company's "statement" model. British Audio Service Inc. has some of the V8 printed circuit boards for sale.
Old 22nd April 2013, 06:57 PM   #12
Make sure you use large high-power pots, at least comparable to what Fender or what Alembic used, if you want the same quality feel and long life.
Old 22nd April 2013, 07:12 PM   #13
The preamp from the V8 is 14 tube stages, so it's a lot more complicated than even the F2B with both channels. It's just that those two (F2B and V8) are my favorites, and quite possibly the two most 'classic' and desirable bass preamps. I assume you know what you wanted, I just thought I'd offer...
Old 22nd April 2013, 08:03 PM   #14
Stormrider is offline Stormrider  United States
Stormrider's Avatar
Send a message via AIM to Stormrider Send a message via MSN to Stormrider
Yes, I'm sticking with the F2B-ish circuit for this project.
Q1 is the output buffer. Just a simple source follower.
I am just sticking with a single channel for now. With that said, this project will probably have more in common with the F1-X, but they're all based on the old Fender preamp anyway.
If I feel the need for more gain, more tone shaping, or a different sound altogether I'll adjust the design later. This could easily just be a starting point.
Also, instead of posting several one line posts just edit your original post, please.
AJ
Old 27th April 2013, 05:16 PM   #15
Stormrider's Avatar
Layout finished. Haven't second checked it yet... The pdf should be 1:1; the board measures 7.25"/3.125". Plan is 1/8" Epoxy G10 material with Keystone 1540-4 turrets. Drawing shows the overall diameter of the turret base, not the hole diameter which is 0.063" for the 1540-4's.
I'm going to do a parts list later, it's all pretty standard. The power supply filter caps are Panasonic Radial 47uF/400V.
AJ
Old 27th April 2013, 07:57 PM   #16
Stormrider's Avatar
Looking throught the transformers at Allied.com I noticed Part # 6K27VF is a modern replacement for the Stancor PS-8415. Same secondaries, mounts the same and has similar dimensions.
AJ
Old 27th April 2013, 08:23 PM   #17
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
just watching, and saying hello cheers
Old 1st May 2013, 06:30 PM   #18
Stormrider's Avatar
Got some time off, and it was a nice spring day so decided it was time to get some real work done on this project out in the garage.
This is the first turret board I've done, so I made a DIY anvil and swage as per the tubedepot plans, with one exception. I had to use a 2" bolt for the anvil as most of my turrets were placed pretty close together. Also, not that the 1540-4 turrets require a 3/32" through hole for swage fitting. Use a #43 drill bit for press fitting.
It was a lot of fun to make, and I think it turned out pretty good.
AJ
Old 1st May 2013, 06:35 PM   #19
Stormrider's Avatar
Last photo
AJ
Old 1st May 2013, 09:27 PM   #20
Why did you decide to make them so close and package tight? Nice work! I just prefer extra space.
Modified Alembic F2-BHide this!Advertise here!
Improving upon the Alembic preamp ClydeWilliam Instruments and Amps 5 29th January 2013 05:59 PM
Alembic F2-B phil mailloux Instruments and Amps 101 12th October 2011 03:07 PM
Alembic F2-B project gone cookoo Nordskov Instruments and Amps 3 17th June 2009 09:03 PM
Pre/PS ala Alembic croat47 Instruments and Amps 3 16th March 2006 02:50 PM
Alembic F-2B mbonus Instruments and Amps 3 3rd March 2006 05:55 PM
Copyright ©1999-2017 diyAudio
