Instruments and Amps Everything that makes music, Especially including instrument amps.
LM3886 By General Guitar Gadget
Old 22nd March 2013, 12:00 PM   #1
ciscothehellspawn is offline ciscothehellspawn
Default LM3886 By General Guitar Gadget
I would like to build the famous general guitar gadgets schematic (http://www.generalguitargadgets.com/...lm3886_amp.pdf)
The short guide indicates a power supply of + - 18v. I know that might be more to pull out more watts... I would go on +-30V at least
Is it possible?
I would like to get about 60w (MONO) into 8ohm
thank you in advance
Old 23rd March 2013, 09:30 PM   #2
JMFahey is offline JMFahey  Argentina
JMFahey's Avatar
Downoad the LM3886 datasheet and follow what it says.
I think max into 8 ohms was 50W, close enough.
Old 23rd March 2013, 11:23 PM   #3
counter culture is offline counter culture  United States
You can get 50W into 8 ohms with +/-35v, but you will need to pay particular attention to heatsinking, use thermal compound at the junction. It'll be that little bit less problematic if you just settle for a bit less output.
Old 25th March 2013, 12:06 PM   #4
wazzy is offline wazzy  Zimbabwe
I have built two of these using the boards but a slightly different schematic, also using a 22-0-22v 300va transformer, dead silent at full volume decent design i found will attach photos as soon as i know how.
Old 25th March 2013, 12:11 PM   #5
thanks! how many watts you have got with this transormer?
Old 25th March 2013, 02:46 PM   #6
JMFahey's Avatar
Probably around 60W into 4 ohms and 40W into 8 ohms.
Old 25th March 2013, 03:12 PM   #7
Enzo is offline Enzo  United States
Going to a lot of trouble to get a few extra watts may niot be as productive as you think. If you went from 25 wats to 50 watts, the result would only be 3 decibels louder.
Old 25th March 2013, 03:22 PM   #8
and 63W gives a further +1db.
But the really important part of going from 25W to 63W is not the extra SPL, but the extra overhead that reduces the incidences of clipped output by raising the clipping threshold by that 4dB.
regards Andrew T.
Old 25th March 2013, 03:27 PM   #9
I would like to get 60w into 8ohm at least, probably a bridge connection of a pair of circuits is needed... I think I'll search for something powerfull... like the tda7294
Old 25th March 2013, 04:24 PM   #10
JMFahey's Avatar
50W and 60W is practically the same, so if you have an easy solution for 50 and a complex one for 60, choose the easier one.
Now if you need 100W or more, then you'll need to go discrete.
The beauty of chipamps is simplicity.
Once you need bridging or (ugh !!!), parallelling, they become as complex as discrete and are not worth it.
Edit: TDA7294 is only slightly more powerful than LM3886, which are far more popular, which means lots of PCB and transformer options, lots of Forum experience to relie on, etc.
But of course, it's your choice.
LM3886 By General Guitar GadgetHide this!Advertise here!
another ebay gadget timwebb Equipment & Tools 72 26th June 2014 10:19 AM
Guitar preamp for LM3886 Mnvizb Instruments and Amps 9 4th December 2011 09:11 PM
Amp Head's for guitar or bass, general interest tinitus Instruments and Amps 9 15th February 2011 11:22 AM
Building a Gainclone with LM3886 General Direction and PSU bmwpowere36m3 Chip Amps 32 24th June 2010 04:10 PM
General guidence building guitar amp mashaffer Instruments and Amps 16 5th December 2007 09:54 PM
Copyright ©1999-2017 diyAudio
