Instruments and Amps Everything that makes music, Especially including instrument amps.
Hybrid "Marshall" Amp
Old 22nd March 2013, 11:27 PM   #11
JonSnell Electronic is online now JonSnell Electronic  United Kingdom
JonSnell Electronic's Avatar
My apologies. The Marshall amp design is designed to give an interesting sound.
Old 23rd March 2013, 05:50 AM   #12
felipemuniz is offline felipemuniz  Brazil
Well, today I made up the jcm800 preamp and tested here with this power amp from 3005, and it sounds very weird, sounds like very dirty distortion and with excessive noise. After that I connected this preamp directly on the V5 of my ac30 (inversor tube) and sounds pretty normal, more agressive that the jcm it self, but i guess that is because the inversor tube of the ac30 design works like a preamp tube too, not just inversor.
I'm now making tests on the power amp, with low gain preamps, using 12au7 tubes. Until now sounds good, but need more tests.
Old 23rd March 2013, 08:37 AM   #13
JMFahey is offline JMFahey  Argentina
JMFahey's Avatar
Does the 3005 power amp work/sound well if you apply guitar signal straight to it?
FWIW I have coupled many times a classic Tube preamp to an SS power amp successfully, but of course considering what Loudthud suggests.
Meaning:
1) attenuate the tube pre signal with, say, a 470K/47K divider
2) place across the SS amp input a couple series, reverse wired Zener diodes, say somewhere around 5V, so no peak higher than that can reach its input.
Although I suspect your SS amp may be unstable or oscillating or you have some ground trouble between preamp and power amp, otherwise you "should" have good sound at least at low settings of the Master Volume.
Old 23rd March 2013, 08:50 AM   #14
Meaning:
The guitar direct on the power amp sounds clean, without problems. Also, with a preamp tube using 2 12au7, until now is sounding good to me.
Well, I already see this that you said with zenners, but with LEDs, in the Vox 15r, I think... I'll try later with zenner and maybe LEDs too.
And about the divider, I used a 1M pot, but I can try a 470K pot too.
edit: the divider is after or before of the diodes?
Old 23rd March 2013, 01:57 PM   #15
JMFahey's Avatar
Ok, you are doing fine.
I didn't want to mention Leds, but it's the same idea, just consider them "1.9V Zeners" and it's fine
The 1M pot is fine, I mentioned 470K as an example.
In fact, I think best would be to use a , say, 470K resistor in series with a 50 to 100K Log pot, for a smoother regulation, but that's up to you.
Good luck.
Old 24th March 2013, 06:45 AM   #16
JRGuitarGuy is offline JRGuitarGuy
Banned
Just find a crate stealth and mod the **** out of it manxD I'm telling you its waaaaay too fun lol Testing New tubes/Caps - YouTube
Love the GEs of course xD
The mullards are some are almost too Holy grail to be in this amp rofl
Blackburn Mullards - YouTube
But it is technically kinda what you are talking about lots solid state junk more in preamp though, not power amp I kinda changed some of that though xD, It does what I wanted it to do with nice RCAs/GEs I have nice Fenderish type tones, get bored with that throw in the mullards then have a raging firestorm 6v6 plexi/jcm from hell etc lol
Old 24th March 2013, 07:10 AM   #17
Banned
SS output would be like holy hell "chainsaw" lol, Not sure tonally what you trying to do? like the wicked more metal speed/thrash or what? lol
Old 29th October 2013, 07:04 AM   #18
Mangekyo24 is offline Mangekyo24  Philippines
Default recently
hi to all, i just build a jcm800 2204 preamp and i modded it for my personal taste.i use SS 120 watt mosfet power amp with full range 100 watt speaker and yeah it works on me. from high impedance on the tube, i find some stuff like filter buffer ss op amp TL072, to filter high impdnce to lower and to matches with the SS power amp. mosfet amp is like tube amp for me i do have the pics stuff so u could see it and need some advice for it too. im a new valve enthusiast. maybe ill post it sooner,..thanks
Hybrid "Marshall" AmpHide this!Advertise here!
"Hybrid A-1000" - Very Old MOSFET amp duane2012 Solid State 3 10th September 2012 05:59 PM
A "Vintage" Integrated Amp Inspired Hybrid regal Headphone Systems 1 29th December 2011 07:12 PM
Hybrid amp Aloia GY-50 "a step beyond of" Stee Solid State 12 27th January 2011 07:19 AM
Marshall "Pighead" schematic. thomj513 Instruments and Amps 7 21st May 2006 07:32 PM
Hybrid "SE Tube Amp Sound Style" Chip Amp idea ThorstenL Chip Amps 24 7th February 2003 06:41 AM
Copyright ©1999-2017 diyAudio
