Instruments and Amps Everything that makes music, Especially including instrument amps.
Boss Super Shifter Help
Old 8th March 2013, 03:19 AM   #1
jbubendorf is offline jbubendorf  United States
Default Boss Super Shifter Help
I recently picked up a Boss PS-5 Super Shifter that won't power up, from Ebay.
After opening it, I found that someone else had previously attempted a repair.
Part of their "repair" was to remove IC8. Does anyone have a schematic or other information? Thanks in advance for the help.
Old 8th March 2013, 06:49 AM   #2
Enzo is offline Enzo  United States
Google "boss ps-5 schematic" and the schematic should be staring back at you about the thrid or fourth thing down.
Old 8th March 2013, 01:57 PM   #3
Thanks for the reply Enzo, and for so many of your replies to other people's questions that have answered questions for me before I have had to ask.
Unfortunately, when I run this search, Google images will show many schematics, but as I click through them, none of them are actually for the PS-5. After hours searching, the only documentation I have found is the user's manual and demo videos. I'm hoping someone here has the schematic, a picture of the board, or maybe even that someone would be willing to crack open their pedal and read me a part number.
Thanks again!
Old 8th March 2013, 03:20 PM   #4
Tesla88 is offline Tesla88  Italy
Tesla88's Avatar
The PS5 is an intelligent harmonizer so it should use a sort of DSP to detect pitch an generate the harmonized note. It's not a simple device and find a schematic would be very hard...
Number of pins of IC8 and package? DIL , SIL , SOIC ecc
Hope it isn't the DSP processor or you can trash the unit...
Old 8th March 2013, 08:41 PM   #5
You are right, I saw the image and didn't look close enough to see they were all for PS-3. Sorry.
Roland might provide a schematic, but they'd want some money for it if they do.
Old 9th March 2013, 04:25 AM   #6
I don't expect it is anything as significant as the DSP. A picture is worth a thousand words though, so have a look...
Old 12th March 2013, 07:31 AM   #7
MereTenacity is offline MereTenacity  United States
Check out StompBoxZone • View topic - Boss RV-5 - It's Not Happy! Looks like the same thing on a different unit. other than electro caps it's identical to your pic. A response lists a replacement, but it's a guess. you could give it a shot.
Old 12th March 2013, 08:42 AM   #8
Tesla88's Avatar
Uhm IC8 seems buruned I think it's a voltage regulator due to the fact it has only 3 PIN and is an Ic (not a transistor or mosfet) , so can be a sort of voltage regulator to provide supply to DSP 3.3 or 5 don't know...Can you read anything on it?
Old 12th March 2013, 08:48 AM   #9
Tesla88's Avatar
Sorry , i've just looked at stomoboxzone and seems a user report it as a
S-8520E33MC-BJS-T2
A PWM regulator to provide 3.3V .. it's hard to find
If you can find the part then fix is easy , only other solution is to use a lineare voltage regulator bypassing this part of the circuit , easy if you are experienced ..
Boss Super Shifter HelpHide this!Advertise here!
Voltage level shifter akis Solid State 4 3rd May 2011 08:21 PM
Cassette transcriber into pitch shifter? seilee1 Everything Else 4 11th December 2007 09:50 PM
Cassette transcriber into pitch shifter? seilee1 Analogue Source 0 6th December 2007 04:15 AM
Level Shifter maverick_123 Class D 1 6th November 2007 11:12 PM
extra transistor in level shifter Tekko Class D 3 27th October 2007 12:32 PM
