Instruments and Amps Everything that makes music, Especially including instrument amps.
Bass/guitar tube preamp with small power stage
Old 18th February 2013, 09:21 AM   #11
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
Originally Posted by Fredde79 View Post
I don't know anything about the ecc99.....What would be the benefits of using the ecc99?
very tough preamp/driver tube
google ecc99 mini amp (its on DIYstompboxes)
might be possible to make it stronger and better
and patiently waiting to see what the ManicMidget is about
Fred Nachbaur's Vacuum Tube Projects
Old 18th February 2013, 11:15 AM   #12
Fredde79 is offline Fredde79  Finland
Ok thanks! Im only wondering if it's necessary since I'll only need line level output, and the only important thing is to match the power tube with the OT. Im not sure how the ecc99 is compared to a 12AU7 soundwise, but if they're roughly the same, a 12AU7 should work equally well (but maybe with a smaller OT).
Also, the ecc99 is physically bigger and I'm planning to fit everything into a 2U rack housing.
Old 18th February 2013, 11:37 AM   #13
Well, this is intended as a bass preamp.
just thinking out loud ...but since you study guitar amps to get inspiration, may be important to consider that they could be designed for overdrive guitar sound....and you may not need that for bass
whatever, I kind of liked your first idea/schematic
don't know why, but I find this site... 'toxicating'
LONE WOLF BLUES COMPANY
Sorry if I was unclear, what I meant was to replace the single ended 6L6 stage in the schematic with a push pull 12AU7 stage.
Like Doug Hammonds FireFly:
you mean only the output stage ?
heck, sometimes there is simply just too much stuff and ideas to try....
Old 18th February 2013, 11:56 AM   #14
Yes, I've thought a lot about that and it's much easier to find schematics for guitar. The idea is to get a clean sound but with the possibility for a *slight* overdrive when pushed. I guess I'll just have to experiment.
One important thing is to get the right B+ voltage for appropriate headroom, but that can be fixed pretty easily by changing the RC-resistors in the PSU. Cathode resistors and capacitors are also easy to change. The difficulty, as I see it, is to get the right output transformer on the first try, since these cost money. I see that the ecc99 mini amp you mentioned uses a Hammond 125B which is 5W, so maybe the 3W version would be enough with 12AU7 as power tubes.
But: I've read that an OT will saturate easier at low frequencies, so I might need a bigger one for bass. I'm not sure about this one though.
Old 18th February 2013, 12:12 PM   #15
This is what de design looks like for the moment:
Old 25th January 2016, 11:51 AM   #16
engel dela pena is offline engel dela pena  Philippines
i found this one,a very detailed project
1 - About the P1800 amp kit
Old 25th January 2016, 12:30 PM   #17
I built my amp in 2013, but was never quite satisfied with the results. I finally ditched the "small power stage" concept and rebuilt the amp as a premp-only type amp. This project is described here: http://www.diyaudio.com/forums/instr...ss-guitar.html
Bass/guitar tube preamp with small power stageHide this!Advertise here!
bass guitar preamp billr Instruments and Amps 19 26th May 2012 03:36 PM
6n6p tube as output tube for small guitar amp moonbird Instruments and Amps 28 7th September 2011 04:28 AM
Preamp for bass guitar destroy2 Instruments and Amps 1 21st June 2011 02:30 PM
tube preamp mod for bass bypass to ss power IN? awangotango Analog Line Level 2 7th January 2011 07:07 PM
small preamp design for a bass guitar Gene_Johnson Instruments and Amps 42 25th November 2009 04:12 PM
Copyright ©1999-2017 diyAudio
