Instruments and Amps Everything that makes music, Especially including instrument amps.
Help with PSU for guitar amp!
Old 29th January 2013, 05:49 PM   #11
Cassiel is offline Cassiel  Libya
I don't understand why you want to drop the voltage down to 280V. Too shy for the EL84. Just drop the current, and I don't think you will get 360V by the way, 340V more likely. Transformer losses.
There should be a prize for whoever gets the voltage right - don't forget to say.
Old 30th January 2013, 07:08 AM   #12
Tesla88 is offline Tesla88  Italy
Tesla88's Avatar
All rectifiers have a certain voltage drop or loss, but it does not depend on rectified voltage.
It certainly does not take 40% of peak voltage !!!
Ok, don't want to be annoyng but , look at some datasheet of the EZ80 , with a 275 - 0 - 275 transformer you get 280Vdc , this is voltage at 90mA , I don't know exactly how much current the OP project need , but with an EL84 and some 12ax7 i think it need at least 60mA , voltage drop is due to tube rectifier loaded and the anodes limiting serie resistors , i expect a B+ voltage around 300-320Vdc
Just don't drop this voltage anymore with CRC networks , expecially for the power stage cause it takes 40-50mA and you need a power resistor to drop voltage at this current and a waste of power when if you apply direct voltage to EL84 stage you get more power and probably a better sounding amp , if you want to drop voltage for preamp stages is ok , they takes few mA and you get a more "hum-free" preamp ...
Anyway , do what ever you want , amp is your
Old 30th January 2013, 07:10 AM   #13
Tesla88's Avatar
How much ? I'll have a bunch of EZ80 at home and some transformer to test !
Old 30th January 2013, 01:26 PM   #14
fizikohemicar is offline fizikohemicar  Serbia
fizikohemicar's Avatar
Ok,ill take B+ for the poweramp,and do a voltage drop for preamp
With B+ at 300V i could get around 6W output,so i will leave like that...
Thanx guys This help means a lot to me!
Help with PSU for guitar amp!Hide this!Advertise here!
Tube guitar amp for acoustic guitar? dagerman Instruments and Amps 15 6th April 2011 02:07 AM
Guitar amplifier PSU hum woes Arnulf Instruments and Amps 33 7th January 2011 05:01 PM
ecl86 & ez80 - suitable for guitar amp? greenstax Instruments and Amps 20 22nd August 2007 10:10 AM
WIll an X-PSU v1 power an SI T-amp &/or TC754 pre-amp? gnostic19 Class D 7 3rd August 2007 01:26 AM
looking for a new spin on guitar fx pedal psu rockstudio Instruments and Amps 2 7th April 2006 03:29 PM
Copyright ©1999-2017 diyAudio
